Up to 20% off select tools
Skytex SP728 Case Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
85
All Time:
667
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
How to remove the back case of the tablet.
    1. Skytex SP728 Case Replacement, Case: step 1, image 1 of 1
      • Make sure the device is powered off
      • Rotate the device so the ports and screws face you
      Ask FixBot
    2. Skytex SP728 Case Replacement: step 2, image 1 of 1
      • Using a small phillips screwdriver, unscrew both end screws
      Ask FixBot
    3. Skytex SP728 Case Replacement: step 3, image 1 of 1
      • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
      Ask FixBot
    4. Skytex SP728 Case Replacement: step 4, image 1 of 1
      • Once the case has been loosened, pry the backing off gently with your hands.
      • Make sure to remove the case gently as extra force can break the clasps or the case itself.
      Ask FixBot
To reassemble your device with a new case, follow these instructions in reverse order.
Author
with
Michelle Strickland
304 Reputation
2 Guides authored
USF Tampa, Team 5-1, Brown Winter 2015 Member of USF Tampa, Team 5-1, Brown Winter 2015
USFT-BROWN-W15S5G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 85
All Time: 667
