Up to 20% off select tools
Skytex SP728 Screen Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
85
All Time:
733
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will show how to take the device apart and how to identify components that need to be removed to replace the screen.
    1. Skytex SP728 Screen Replacement, Case: step 1, image 1 of 1
      • Make sure the device is powered off
      • Rotate the device so the ports and screws face you
      Ask FixBot
    2. Skytex SP728 Screen Replacement: step 2, image 1 of 1
      • Using a small phillips screwdriver, unscrew both end screws
      Ask FixBot
    3. Skytex SP728 Screen Replacement: step 3, image 1 of 1
      • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
      Ask FixBot
    4. Skytex SP728 Screen Replacement: step 4, image 1 of 1
      • Once the case has been loosened, pry the backing off gently with your hands.
      • Make sure to remove the case gently as extra force can break the clasps or the case itself.
      Ask FixBot
    1. Skytex SP728 Screen Replacement, Screen: step 5, image 1 of 3 Skytex SP728 Screen Replacement, Screen: step 5, image 2 of 3 Skytex SP728 Screen Replacement, Screen: step 5, image 3 of 3
      • Follow the Case Replacement to separate the tablet from its backing
      • Using a small Phillips screw driver, unscrew all screws connecting circuit board to device
      • Remove all tape connecting battery and circuit board to front case
      • Detach all connector strips from the circuit board
      Ask FixBot
    2. Skytex SP728 Screen Replacement: step 6, image 1 of 2 Skytex SP728 Screen Replacement: step 6, image 2 of 2
      • Using the plastic opening tool, begin separating the front screen from the display
      Ask FixBot
    3. Skytex SP728 Screen Replacement: step 7, image 1 of 1
      Tool used on this step:
      Buy
      • Once screen has been separated, use tweezers to remove front camera
      Ask FixBot
To reassemble your device with a new screen, follow these instructions in reverse order.
2 other people completed this guide.
Author
with
Michelle Strickland
304 Reputation
2 Guides authored
USF Tampa, Team 5-1, Brown Winter 2015 Member of USF Tampa, Team 5-1, Brown Winter 2015
USFT-BROWN-W15S5G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 85
All Time: 733
