Up to 20% off select tools
Skytex SP728 Battery Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
106
All Time:
1,339
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Parts
Tools
Introduction
Go to step 1 ↓
This repair guide will walk you through the primary steps of replacing the battery in the Skytex Skypad SP728.
    1. Skytex SP728 Battery  Replacement, Case: step 1, image 1 of 1
      • Make sure the device is powered off
      • Rotate the device so the ports and screws face you
      Ask FixBot
    2. Skytex SP728 Battery  Replacement: step 2, image 1 of 1
      • Using a small phillips screwdriver, unscrew both end screws
      Ask FixBot
    3. Skytex SP728 Battery  Replacement: step 3, image 1 of 1
      • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
      Ask FixBot
    4. Skytex SP728 Battery  Replacement: step 4, image 1 of 1
      • Once the case has been loosened, pry the backing off gently with your hands.
      • Make sure to remove the case gently as extra force can break the clasps or the case itself.
      Ask FixBot
    1. Skytex SP728 Battery  Replacement, Battery: step 5, image 1 of 1
      • Remove the yellow and black tape around the battery very carefully
      Ask FixBot
    2. Skytex SP728 Battery  Replacement: step 6, image 1 of 2 Skytex SP728 Battery  Replacement: step 6, image 2 of 2
      • Use the soldering iron and remove soldered connections to separate the wires connected to the battery from the circuit board.
      • Follow the link below for additional soldering information How To Solder and Desolder Connections
      • Soldering uses heat so make sure you are careful while doing it. Also, excessive heat can damage the components. So do not apply the soldering iron on a component for extended periods of time.
      Ask FixBot
    3. Skytex SP728 Battery  Replacement: step 7, image 1 of 1
      • Using the plastic opening tool, lift up the battery from right edge and set aside.
      • Make sure that you take the battery out very carefully without bending it or damaging it as it contains toxic chemicals.
      • While soldering the wires for the new battery, remember that the red wire has to be connected to the positive terminal and the black wire has to be connected to the negative terminal.
      Ask FixBot
To reassemble your device with a new battery, follow these instructions in reverse order.
Author
with
Galika Adhikari
248 Reputation
2 Guides authored
USF Tampa, Team 5-1, Brown Winter 2015 Member of USF Tampa, Team 5-1, Brown Winter 2015
USFT-BROWN-W15S5G1
4 Members
72 Guides authored
1 Guide Comment
Money gimme now
Brayden Spiller - Reply Share
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 106
All Time: 1,339
