How to clean/replace buttons on the Skytex SP728
    1. How to clean/replace buttons on the Skytex SP728, Case: step 1, image 1 of 1
      • Make sure the device is powered off
      • Rotate the device so the ports and screws face you
      Ask FixBot
    2. How to clean/replace buttons on the Skytex SP728: step 2, image 1 of 1
      • Using a small phillips screwdriver, unscrew both end screws
      Ask FixBot
    3. How to clean/replace buttons on the Skytex SP728: step 3, image 1 of 1
      • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
      Ask FixBot
    4. How to clean/replace buttons on the Skytex SP728: step 4, image 1 of 1
      • Once the case has been loosened, pry the backing off gently with your hands.
      • Make sure to remove the case gently as extra force can break the clasps or the case itself.
      Ask FixBot
    1. How to clean/replace buttons on the Skytex SP728, How to clean/replace buttons on the Skytex SP728: step 5, image 1 of 1
      • Remove the black buttons (they should not be directly attached to the device and may fall out).
      Ask FixBot
    2. How to clean/replace buttons on the Skytex SP728: step 6, image 1 of 1
      • On side the circuit board there will be three buttons. One is the power button, and the other two are volume buttons.
      Ask FixBot
Chris Nelson
219 Reputation
2 Guides authored
USF Tampa, Team 5-1, Brown Winter 2015 Member of USF Tampa, Team 5-1, Brown Winter 2015
USFT-BROWN-W15S5G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 60
All Time: 360
