Page Stub
This wiki page is a stub. Help us improve this page by adding information to it!
Disk won't read
  • If playback skipping is present, the
Optical Sensor
might be dirty or malfunctioning.
No audio/video output
  • Make sure all connectors are clean and are firmly connected to proper port.
  • Internal connection of audio/video outputs are disrupted and no longer connected to main printed circuit board.
  • Logic Board or Power Board is malfunctioning.
Disk tray won't eject
  • A disk may be stuck in the DVD drive. Listen to hear if the motor and gears are turning properly.
  • The Disk Tray Motor may be malfunctioning.
  • This problem could also be due to unresponsive controls. If this is the case, the Function Board or Control Board may not be working correctly.
Unresponsive controls
  • Control printed circuit board is malfunctioning. This prevents the signal from the front panel from reaching the main board.
  • Logic Board is malfunctioning. Usually there are other problems associated with this one.
Author
with
Tane
62 Reputation
0 Guides authored
Cal Poly, Team 18-20, Garner Spring 2011 Member of Cal Poly, Team 18-20, Garner Spring 2011
CPSU-GARNER-S11S18G20
4 Members
132 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 4,894
