Up to 20% off select tools
Removing Panasonic DVD-RV31 Player Motherboard
Views: 4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
28
Past 30 Days:
104
All Time:
4,016
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 5 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
    1. Removing Panasonic DVD-RV31 Player Motherboard, Disk Tray Cover: step 1, image 1 of 1
      • Eject the disk tray from the DVD player before removing power supply.
      Ask FixBot
    2. Removing Panasonic DVD-RV31 Player Motherboard: step 2, image 1 of 1
      • Evenly lift upward on the disk tray front cover (not slanted, as pictured). This will allow for easier disassembly of the player.
      Ask FixBot
    1. Removing Panasonic DVD-RV31 Player Motherboard, Outer Case: step 3, image 1 of 2 Removing Panasonic DVD-RV31 Player Motherboard, Outer Case: step 3, image 2 of 2
      • Remove the three screws running along the back edge of case cover.
      • Remove the two screws from each side of the case cover.
      Ask FixBot
    2. Removing Panasonic DVD-RV31 Player Motherboard: step 4, image 1 of 1
      • Grab edges of the cover with your hands. Pull outward slightly, then straight up.
      Ask FixBot
    1. Removing Panasonic DVD-RV31 Player Motherboard, Front Panel: step 5, image 1 of 2 Removing Panasonic DVD-RV31 Player Motherboard, Front Panel: step 5, image 2 of 2
      • Lift up the five tabs securing the front panel to the chassis. There are three on the bottom, and two on the inside edges of the panel. Panel should then lift off the player.
      Ask FixBot
    1. Removing Panasonic DVD-RV31 Player Motherboard, Motherboard: step 6, image 1 of 2 Removing Panasonic DVD-RV31 Player Motherboard, Motherboard: step 6, image 2 of 2
      • Remove the blue ribbon wire from its connector. When doing this, be cautious to not damage the connector.
      • Place forefinger under cable loop as shown, gripping with thumb.
      • Pull straight up. It should disconnect with little force.
      Ask FixBot
    2. Removing Panasonic DVD-RV31 Player Motherboard: step 7, image 1 of 2 Removing Panasonic DVD-RV31 Player Motherboard: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • Using tweezers or pliers, squeeze the tabs of the plastic fasteners together. While doing this, gently lift up on the motherboard until the fasteners are released.
      Ask FixBot
    3. Removing Panasonic DVD-RV31 Player Motherboard: step 8, image 1 of 1
      • Remove the two screws securing the motherboard using a philips screw driver.
      Ask FixBot
    4. Removing Panasonic DVD-RV31 Player Motherboard: step 9, image 1 of 1
      • Lift the board from the side closest to the front panel (top of photo).
      • Gently apply force until bottom connector releases from power board below.
      Ask FixBot
Author
with
Kevin
375 Reputation
8 Guides authored
Cal Poly, Team 18-20, Garner Spring 2011 Member of Cal Poly, Team 18-20, Garner Spring 2011
CPSU-GARNER-S11S18G20
4 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 104
All Time: 4,016
