Up to 20% off select tools
Panasonic DVD-RV31 Player Disc Retainer Replacement
Views: 6.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
103
All Time:
6,276
Comments: 4
4 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Difficult
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Panasonic DVD-RV31 Player Disc Retainer Replacement, Disk Tray Cover: step 1, image 1 of 1
      • Eject the disk tray from the DVD player before removing power supply.
      Ask FixBot
    2. Panasonic DVD-RV31 Player Disc Retainer Replacement: step 2, image 1 of 1
      • Evenly lift upward on the disk tray front cover (not slanted, as pictured). This will allow for easier disassembly of the player.
      Ask FixBot
    1. Panasonic DVD-RV31 Player Disc Retainer Replacement, Outer Case: step 3, image 1 of 2 Panasonic DVD-RV31 Player Disc Retainer Replacement, Outer Case: step 3, image 2 of 2
      • Remove the three screws running along the back edge of case cover.
      • Remove the two screws from each side of the case cover.
      Ask FixBot
    2. Panasonic DVD-RV31 Player Disc Retainer Replacement: step 4, image 1 of 1
      • Grab edges of the cover with your hands. Pull outward slightly, then straight up.
      Ask FixBot
    1. Panasonic DVD-RV31 Player Disc Retainer Replacement, Front Panel: step 5, image 1 of 2 Panasonic DVD-RV31 Player Disc Retainer Replacement, Front Panel: step 5, image 2 of 2
      • Lift up the five tabs securing the front panel to the chassis. There are three on the bottom, and two on the inside edges of the panel. Panel should then lift off the player.
      Ask FixBot
    1. Panasonic DVD-RV31 Player Disc Retainer Replacement, Disk Drive: step 6, image 1 of 3 Panasonic DVD-RV31 Player Disc Retainer Replacement, Disk Drive: step 6, image 2 of 3 Panasonic DVD-RV31 Player Disc Retainer Replacement, Disk Drive: step 6, image 3 of 3
      • Locate the four screws securing the disk drive assembly. There are two on each side.
      • Use a narrow screwdriver to remove all four screws.
      • Remove the blue ribbon wire from its connector. When doing this, be cautious to not damage the connector.
      Ask FixBot
    2. Panasonic DVD-RV31 Player Disc Retainer Replacement: step 7, image 1 of 1
      • Lift assembly by the front to pull metal bracket from the power board.
      • Pull up back end and lift drive out.
      Ask FixBot
    3. Panasonic DVD-RV31 Player Disc Retainer Replacement: step 8, image 1 of 1
      • With the drive assembly separate from the player, hold as shown and pull the bracket edges away from the disk drive.
      • Lift bracket off and reserve for re-assembly.
      Ask FixBot
    1. Panasonic DVD-RV31 Player Disc Retainer Replacement, Disc Retainer: step 9, image 1 of 3 Panasonic DVD-RV31 Player Disc Retainer Replacement, Disc Retainer: step 9, image 2 of 3 Panasonic DVD-RV31 Player Disc Retainer Replacement, Disc Retainer: step 9, image 3 of 3
      • Grasp the bridge above the wheel and push the tabs on the side as shown.
      • Pull down firmly and away from the laser housing.
      Ask FixBot
3 other people completed this guide.
Author
with
Kevin
375 Reputation
8 Guides authored
Cal Poly, Team 18-20, Garner Spring 2011 Member of Cal Poly, Team 18-20, Garner Spring 2011
CPSU-GARNER-S11S18G20
4 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 103
All Time: 6,276
