Up to 20% off select tools
Panasonic DVD-RV31 Player Left Control Board Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
4
Past 7 Days:
23
Past 30 Days:
90
All Time:
2,764
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 5 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Panasonic DVD-RV31 Player Left Control Board Replacement, Outer Case: step 1, image 1 of 2 Panasonic DVD-RV31 Player Left Control Board Replacement, Outer Case: step 1, image 2 of 2
      • Remove the three screws running along the back edge of case cover.
      • Remove the two screws from each side of the case cover.
      Ask FixBot
    2. Panasonic DVD-RV31 Player Left Control Board Replacement: step 2, image 1 of 1
      • Grab edges of the cover with your hands. Pull outward slightly, then straight up.
      Ask FixBot
    1. Panasonic DVD-RV31 Player Left Control Board Replacement, Front Panel: step 3, image 1 of 2 Panasonic DVD-RV31 Player Left Control Board Replacement, Front Panel: step 3, image 2 of 2
      • Lift up the five tabs securing the front panel to the chassis. There are three on the bottom, and two on the inside edges of the panel. Panel should then lift off the player.
      Ask FixBot
    1. Panasonic DVD-RV31 Player Left Control Board Replacement, Left Control Board: step 4, image 1 of 2 Panasonic DVD-RV31 Player Left Control Board Replacement, Left Control Board: step 4, image 2 of 2
      • Grip jogger dial and lift up. It should come off easily.
      Ask FixBot
    2. Panasonic DVD-RV31 Player Left Control Board Replacement: step 5, image 1 of 3 Panasonic DVD-RV31 Player Left Control Board Replacement: step 5, image 2 of 3 Panasonic DVD-RV31 Player Left Control Board Replacement: step 5, image 3 of 3
      • Remove 4 mounting screws as shown.
      • Unscrew and save brass tab.
      • Push in 2 plastic retainers and lift out.
      Ask FixBot
Author
with
Kevin
375 Reputation
8 Guides authored
Cal Poly, Team 18-20, Garner Spring 2011 Member of Cal Poly, Team 18-20, Garner Spring 2011
CPSU-GARNER-S11S18G20
4 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 90
All Time: 2,764
