Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Computer Will Not Charge Efficiently
Your computer will not charge, or it will charge but lose battery quickly.
Power Adapter Not Plugged In
Sometimes your computer’s power adapter is not properly plugged. Check that all parts of the power adapter are properly connected while also looking for possible cuts or damage. If computer does not show the charging light while plugged properly or the adapter appears damaged, the adapter might be faulty. Consider purchasing a replacement.
Battery Life Inefficient
If the adapter is plugged and working but the battery does not charge, or the battery life decreases rapidly after the removal of the adapter from the computer’s charging port. The computer’s battery needs replacement. Try replacing the battery with this guide.
Programs Running Slowly
Your computer is running slowly, precisely the programs launched after startup.
Corrupted Files
Sometimes important files for a program to run can get corrupted. It might make it slow or it does not run at all. To resolve this issue, reinstall the programs by going to Control Panel > uninstall a program. Select the desired program and select Uninstall. After the program is uninstalled. You will need to install it again.
Not Enough Memory RAM
If you computer is running slow or a program crash during intensive use, you might not have enough memory RAM. Ensure that the computer has enough memory RAM to run the desired software. To check it, search for "system property" at the windows search bar. It will show how much memory is installed. If not enough, consider upgrading it by using this guide.
Mechanical Hard Drive Malfunctioning
Sometimes mechanical hard drive malfunction, it is a delicate piece and susceptible to damage if dropped or with a rough impact. It will impact overall performance in the computer and also on programs. Try replacing it for a Solid-State Drive (SSD) by using this guide.
Keyboard Unresponsive/Keys Not Working
Your keyboard won't respond to keys pressed or some keys are stuck.
Keys Stuck
If some of the keys are hard to press, there might be something stuck underneath the keys. You can fix this by removing the individual key and check to see if there is something interfering with its function. Once it is done, replace it.
Malfunctioning Keyboard
If your whole keyboard does not work. Try replacing it by using this guide.
Computer Is Heating Up Too Much
My computer is heating up extremely fast, even when it’s not doing high workload and it shuts down.
Dust in Vents or Fans
Computers can overheat due to excessive dust and other materials stuck in the vents or fan. You can  fix this by using a compressed air duster to carefully blow the dust off the vents and fan. Make sure the vent is getting sufficient cooling and air while placed on your lap or desk. For fans replacement use this guide.
Inadequate Amount of Thermal Paste
Your computer may not have adequate contact between the heat sink and processor. This is usually caused by a lack of thermal paste or by air in between the two components. To fix this, completely clean off any old thermal paste, then apply a bead of new thermal paste directly in the center of the processor. Gently push the heat sink back in place and tighten screws to lock down the heat sink.
WiFi and Bluetooth do not connect to any networks
My computer WiFi does not connect to any network and my Bluetooth doesn’t connect to other devices.
Faulty WiFi and Bluetooth Adapter
Your computer may not receive signal due to a broken adapter, buy a new one and check to make sure Bluetooth connection is in good condition. For WiFi/Bluetooth replacement use this guide.
Christian Abad
1,780 Reputation
7 Guides authored
1 Comment
My laptop turns on but screen doesn't . It stays black how to solve this problem?
priyabrat nayak - Reply Share
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 64
All Time: 2,988
