Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Camera Will Not Turn On
No matter what you do, you can't get your camera to turn on.
Drained/Bad Battery
If your camera will not turn on, check to see if the battery is properly inserted in the camera and charged. If the camera still wont turn on then the battery is defective and you will need to change out the battery. This could be simply from a defective battery from the factory, the battery can go bad over time or the battery receives physical damage then you will need to replace the battery with a new one.
Pictures are Distorted
The pictures in the camera are distorted or corrupted
Optical Assembly is Defective
If the camera consistently takes blurry or distorted pictures the optical assembly is not working properly. This could happen for a variety of reasons. If the camera is dropped or treated roughly this could cause the optical assembly to cause your camera to take blurry pictures. The best course of action is to simply replace the whole unit.
Memory Card Will Not Save, or Cannot be Read
If the memory card is not working properly you should make sure the memory card is compatible with the camera. If the memory card is compatible then try a different memory card. If both memory cards do not work then the problem is with the camera.
Physical Damage to Camera
There is Physical Damage to the Camera
Front Case Damage
The front case is damaged in some way. It has scratches or cracks. See our replacement guide to show how to replace it.
Rear Case Damage
The rear case is damaged in some way. It has scratches or cracks. To replace it see our replacement guide.
Scratched Camera Lens
The lens can be damaged from being dropped or abrasive material scratches the lens.
If the outside lens gets some scratches on it, then the scratches will cause the picture quality to be poor from showing up on your images. The best course of action would be to replace the outer lens.
Shutter will not Open
If the Shutter will not open when the camera is on check first if you are in picture mode. If it still will not open then you will need to replace or clean the shutter as it may have something clogging it or it may just be broken. After inspecting the shutter to see if it is simple not being prevented from opening by being dirty, then replacing the shutter is the only course of action.
LCD Screen Cracked or Will Not Turn On
If your LCD screen is cracked or damaged in some way. It will not light up, or the image is distorted, or you have dead pixels the best course of action is to replace the LCD screen unit. Our replacement guide will show you how to replace the LCD screen in case of damage.
LCD Control Panel
The dial or buttons to control the LCD screen is unresponsive or does not accept input. Our replacement guide will show you how to replace this part.
Top Dials Are Broken or Do Not Function
The top control dials are broken off or are unresponsive and do not accept input. Our replacement guide will show you how to change out this part.
Camera’s Flash Will Not Work
The Flash Will Not Light When Taking a Picture
Flash is Turned Off
Check to see if your camera has flash turned off, this would be the most common issue with flash not going off when taking a picture.
Flash Bulb is Dead
If the flash bulb is dead and the camera does not flash when you are trying to use it, then the flash bulb needs to be replaced. The flash bulb is attached to a unit connected to a very strong capacitor and it could shock you if you attempt to replace it yourself.
Pablo Martinez
163 Reputation
1 Guide authored
USF Tampa, Team 5-6, Brown Winter 2015 Member of USF Tampa, Team 5-6, Brown Winter 2015
USFT-BROWN-W15S5G6
3 Members
60 Guides authored
5 Comments
Dust on sensor. How does one get to see the sensor?
Adrian Midgley - Reply Share
My G11 shows no image on the screen. After a few seconds of trying to focus the screen goes black. No idea what is going on.
terra_nostra_mx - Reply Share
This camera’s biggest problem is a LENS ERROR fault during which the lens won’t extend and the camera then shuts down. I’ve had 4 G11s and this is what kills them. Had one repaired—lasted a year or so, then the same problem killed the camera.
Lee Thé - Reply Share
I tried a few SDK and they are all working fine on computer.
But when I used it on G11, it works sometime and stop working from time to time... but they all work very well on computer.
So I believe is the reading components on the camera that has problem... do you think this is fixable ??
Thanks!!
yanranxiaozhi - Reply Share
How can a repair lens scratches? My camera takes acceptable pictures near, but from far, landscapes, they are blurred.
learsito007 - Reply Share
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 71
All Time: 5,438
