Canon PowerShot G11 LCD Screen Replacement
Views: 6.2K
View statistics:
Past 24 Hours:
8
Past 7 Days:
27
Past 30 Days:
139
All Time:
6,211
Comments: 5
1 comment on steps, 4 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If the LCD screen of your Canon PowerShot G11 LCD is cracked or has stopped working you will need to replace it.
Tools
    1. Canon PowerShot G11 LCD Screen Replacement, LCD Screen: step 1, image 1 of 1
      • Remove the two 3.10mm Phillips #00 screws from the LCD case.
      Ask FixBot
    2. Canon PowerShot G11 LCD Screen Replacement: step 2, image 1 of 1
      • Open the LCD screen and turn it so the screen is facing the bottom of the camera, the screw is on the bottom of the LCD screen.
      • Remove the 3.10mm Philips #00 screw from the bottom end of the LCD screen.
      Ask FixBot
    3. Canon PowerShot G11 LCD Screen Replacement: step 3, image 1 of 1
      • Turn the LCD so that the screen is facing the top of the camera, the screw you need is on the bottom of the LCD screen.
      • Remove the 3.10mm Philips #00 screw.
      Ask FixBot
    4. Canon PowerShot G11 LCD Screen Replacement: step 4, image 1 of 1
      • Use the plastic opening tool on the indent at the top of the LCD screen to pop off the LCD case.
      Ask FixBot
    5. Canon PowerShot G11 LCD Screen Replacement: step 5, image 1 of 2 Canon PowerShot G11 LCD Screen Replacement: step 5, image 2 of 2
      • Remove the 2.22mm Phillips #00 screw that is located next to the indent handle.
      • When the top screw is removed the small metal bracket will fall out, when reassembling the LCD screen remember to put it back on.
      Ask FixBot
    6. Canon PowerShot G11 LCD Screen Replacement: step 6, image 1 of 2 Canon PowerShot G11 LCD Screen Replacement: step 6, image 2 of 2
      • Once the back panel is off remove the two 3.13mm Philips #00 screws.
      • There are magnets next the screws so when you reassemble the LCD screen make note of this, they will move the screws.
      Ask FixBot
    7. Canon PowerShot G11 LCD Screen Replacement: step 7, image 1 of 2 Canon PowerShot G11 LCD Screen Replacement: step 7, image 2 of 2
      • On the bottom of the LCD screen carefully turn it so the screen is facing the top of the camera and remove the 2.22mm Phillips #00 screw.
      • Once this screw comes off the top case will come off and the LCD screen will be held by only the wires so handle it carefully so as not to damage the wires.
      Ask FixBot
    8. Canon PowerShot G11 LCD Screen Replacement: step 8, image 1 of 3 Canon PowerShot G11 LCD Screen Replacement: step 8, image 2 of 3 Canon PowerShot G11 LCD Screen Replacement: step 8, image 3 of 3
      • Remove the screen from the base of the LCD.
      • Do not pull because the wire strip is still attached to the LCD base.
      • Do not remove this wire, it is not needed when replacing the screen.
      Ask FixBot
    9. Canon PowerShot G11 LCD Screen Replacement: step 9, image 1 of 3 Canon PowerShot G11 LCD Screen Replacement: step 9, image 2 of 3 Canon PowerShot G11 LCD Screen Replacement: step 9, image 3 of 3
      Tool used on this step:
      Buy
      • Use the tweezers to lift the small brown plastic snap before you remove the wire.
      Ask FixBot
2 other people completed this guide.
Pablo Martinez
163 Reputation
1 Guide authored
USF Tampa, Team 5-6, Brown Winter 2015 Member of USF Tampa, Team 5-6, Brown Winter 2015
USFT-BROWN-W15S5G6
3 Members
60 Guides authored
4 Guide Comments
Did this. The first time i put it ack together it did not work , Had totake apart and adjust wires okay after put bake together again.
Jim Murphy - Reply Share
Followed these instructions and the result is excellent. Well done, and thanks very much. Saved me buying another camera!
Steve Rayner - Reply Share
How do you get a new screen on there?
Jacob Fields - Reply Share
Faltan planos. Por arte de magia el lcd aparece a la izquierda de varias fotos cuando debería estar debajo de la placa verde. Perdonen, muy mal explicado.
jlmgbaquero007 - Reply Share
Past 24 Hours: 8
Past 7 Days: 27
Past 30 Days: 139
All Time: 6,211
