Canon PowerShot G11 Top Cover Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
88
All Time:
2,301
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Canon PowerShot G11 Top Cover Replacement, Front Cover: step 1, image 1 of 2 Canon PowerShot G11 Top Cover Replacement, Front Cover: step 1, image 2 of 2
      • Push the button on the bottom right of the camera and then remove the plastic surrounding the lens.
      Ask FixBot
    2. Canon PowerShot G11 Top Cover Replacement: step 2, image 1 of 1
      • Use the spudger to pop off front case.
      Ask FixBot
    3. Canon PowerShot G11 Top Cover Replacement: step 3, image 1 of 1
      • Pull the loosened cover off and you are finished.
      Ask FixBot
    1. Canon PowerShot G11 Top Cover Replacement, Top Cover: step 4, image 1 of 1
      • Once both the front and rear covers are removed, disconnect this ribbon cable by flipping it up and disconnecting it.
      Ask FixBot
    2. Canon PowerShot G11 Top Cover Replacement: step 5, image 1 of 1
      • Remove these three screws from the rear side of the camera.
      Ask FixBot
    3. Canon PowerShot G11 Top Cover Replacement: step 6, image 1 of 1
      • Remove this screw from the front of the camera.
      Ask FixBot
    4. Canon PowerShot G11 Top Cover Replacement: step 7, image 1 of 1
      • Disconnect this cable from the motherboard by sliding it in the direction of the cable (toward the top of the camera).
      Ask FixBot
    5. Canon PowerShot G11 Top Cover Replacement: step 8, image 1 of 1
      • Remove the top cover and you are finished.
      Ask FixBot
Dustin Brinegar
715 Reputation
4 Guides authored
USF Tampa, Team 5-6, Brown Winter 2015 Member of USF Tampa, Team 5-6, Brown Winter 2015
USFT-BROWN-W15S5G6
3 Members
60 Guides authored
1 Guide Comment
In step 5, it is only necessary to take out the 2 SST screws at ~ 10 and 3 o’clock. The grey screw at 7 stays with the body.
In step 7, you need to SLIDE the connector toward the top of the camera toward the dial. The tweezers in the photo are moving LEFT, not toward the viewer as I interpreted it. If you lift it up as if to disconnect a socket (like in step 4) away from the mother board with tweezers, you’ll easily destroy the delicate connector (as I found out).
Dimwit - Reply Share
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 88
All Time: 2,301
