Canon PowerShot G11 Front Cover Replacement
Views: 3.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
27
Past 30 Days:
103
All Time:
3,062
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The device should be turned off and the battery and memory card removed before you start the guide.
Tools
    1. Canon PowerShot G11 Front Cover Replacement, Rear Cover: step 1, image 1 of 1
      • Remove the three screws on the bottom of the camera using the 00 sized phillips head screw driver.
      Ask FixBot
    2. Canon PowerShot G11 Front Cover Replacement: step 2, image 1 of 1
      • Remove the four screws on the left side of the camera.
      Ask FixBot
    3. Canon PowerShot G11 Front Cover Replacement: step 3, image 1 of 1
      • Remove the screw on the right side of the camera.
      Ask FixBot
    4. Canon PowerShot G11 Front Cover Replacement: step 4, image 1 of 1
      • Open up the HDMI port on the right side of the camera. Then remove the screw in the HDMI port.
      Ask FixBot
    5. Canon PowerShot G11 Front Cover Replacement: step 5, image 1 of 1
      • Remove the screw to the right of the view finder on the rear of the camera.
      Ask FixBot
    6. Canon PowerShot G11 Front Cover Replacement: step 6, image 1 of 1
      • Use the spudger to crack open the case.
      Ask FixBot
    7. Canon PowerShot G11 Front Cover Replacement: step 7, image 1 of 1
      Tool used on this step:
      Buy
      • The rear case is still attached to the camera with a ribbon cable. The socket has a flip up lid that must be flipped up before the cable can be removed. Use the tweezers to flip the cable attachment up.
      Ask FixBot
    8. Canon PowerShot G11 Front Cover Replacement: step 8, image 1 of 1
      • The rear cover is now unattached from the camera.
      Ask FixBot
    1. Canon PowerShot G11 Front Cover Replacement, Front Cover: step 9, image 1 of 2 Canon PowerShot G11 Front Cover Replacement, Front Cover: step 9, image 2 of 2
      • Push the button on the bottom right of the camera and then remove the plastic surrounding the lens.
      Ask FixBot
    2. Canon PowerShot G11 Front Cover Replacement: step 10, image 1 of 1
      • Use the spudger to pop off front case.
      Ask FixBot
    3. Canon PowerShot G11 Front Cover Replacement: step 11, image 1 of 1
      • Pull the loosened cover off and you are finished.
      Ask FixBot
3 other people completed this guide.
Dustin Brinegar
715 Reputation
4 Guides authored
USF Tampa, Team 5-6, Brown Winter 2015 Member of USF Tampa, Team 5-6, Brown Winter 2015
USFT-BROWN-W15S5G6
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 103
All Time: 3,062
