Canon PowerShot G11 Rear Cover Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
85
All Time:
1,591
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Turning off the camera, removing the battery, and removing the memory card. Unplugging the camera from any device it is hooked up to.
Tools
    1. Canon PowerShot G11 Rear Cover Replacement, Rear Cover: step 1, image 1 of 1
      • Remove the three screws on the bottom of the camera using the 00 sized phillips head screw driver.
      Ask FixBot
    2. Canon PowerShot G11 Rear Cover Replacement: step 2, image 1 of 1
      • Remove the four screws on the left side of the camera.
      Ask FixBot
    3. Canon PowerShot G11 Rear Cover Replacement: step 3, image 1 of 1
      • Remove the screw on the right side of the camera.
      Ask FixBot
    4. Canon PowerShot G11 Rear Cover Replacement: step 4, image 1 of 1
      • Open up the HDMI port on the right side of the camera. Then remove the screw in the HDMI port.
      Ask FixBot
    5. Canon PowerShot G11 Rear Cover Replacement: step 5, image 1 of 1
      • Remove the screw to the right of the view finder on the rear of the camera.
      Ask FixBot
    6. Canon PowerShot G11 Rear Cover Replacement: step 6, image 1 of 1
      • Use the spudger to crack open the case.
      Ask FixBot
    7. Canon PowerShot G11 Rear Cover Replacement: step 7, image 1 of 1
      Tool used on this step:
      Buy
      • The rear case is still attached to the camera with a ribbon cable. The socket has a flip up lid that must be flipped up before the cable can be removed. Use the tweezers to flip the cable attachment up.
      Ask FixBot
    8. Canon PowerShot G11 Rear Cover Replacement: step 8, image 1 of 1
      • The rear cover is now unattached from the camera.
      Ask FixBot
Dustin Brinegar
715 Reputation
4 Guides authored
USF Tampa, Team 5-6, Brown Winter 2015 Member of USF Tampa, Team 5-6, Brown Winter 2015
USFT-BROWN-W15S5G6
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 85
All Time: 1,591
