Canon PowerShot G11 Rear Dial Replacement
Views: 3K
View statistics:
Past 24 Hours:
Past 7 Days:
30
Past 30 Days:
118
All Time:
3,004
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Easy
Tools
    1. Canon PowerShot G11 Rear Dial Replacement, Rear Cover: step 1, image 1 of 1
      • Remove the three screws on the bottom of the camera using the 00 sized phillips head screw driver.
      Ask FixBot
    2. Canon PowerShot G11 Rear Dial Replacement: step 2, image 1 of 1
      • Remove the four screws on the left side of the camera.
      Ask FixBot
    3. Canon PowerShot G11 Rear Dial Replacement: step 3, image 1 of 1
      • Remove the screw on the right side of the camera.
      Ask FixBot
    4. Canon PowerShot G11 Rear Dial Replacement: step 4, image 1 of 1
      • Open up the HDMI port on the right side of the camera. Then remove the screw in the HDMI port.
      Ask FixBot
    5. Canon PowerShot G11 Rear Dial Replacement: step 5, image 1 of 1
      • Remove the screw to the right of the view finder on the rear of the camera.
      Ask FixBot
    6. Canon PowerShot G11 Rear Dial Replacement: step 6, image 1 of 1
      • Use the spudger to crack open the case.
      Ask FixBot
    7. Canon PowerShot G11 Rear Dial Replacement: step 7, image 1 of 1
      Tool used on this step:
      Buy
      • The rear case is still attached to the camera with a ribbon cable. The socket has a flip up lid that must be flipped up before the cable can be removed. Use the tweezers to flip the cable attachment up.
      Ask FixBot
    8. Canon PowerShot G11 Rear Dial Replacement: step 8, image 1 of 1
      • The rear cover is now unattached from the camera.
      Ask FixBot
    1. Canon PowerShot G11 Rear Dial Replacement, Rear Dial: step 9, image 1 of 1
      • Remove the plastic covering of the left side of the rear case interior.
      Ask FixBot
    2. Canon PowerShot G11 Rear Dial Replacement: step 10, image 1 of 1
      • Remove the four screws that are now accessible with the removal of the plastic covering them.
      Ask FixBot
    3. Canon PowerShot G11 Rear Dial Replacement: step 11, image 1 of 2 Canon PowerShot G11 Rear Dial Replacement: step 11, image 2 of 2
      • After the screws are removed, pull the metal bracket out of the camera.
      Ask FixBot
    4. Canon PowerShot G11 Rear Dial Replacement: step 12, image 1 of 1
      • Push the dial out from the other side of the cover.
      Ask FixBot
    5. Canon PowerShot G11 Rear Dial Replacement: step 13, image 1 of 1
      • Remove the dial from the case completely.
      Ask FixBot
3 other people completed this guide.
Dustin Brinegar
715 Reputation
4 Guides authored
USF Tampa, Team 5-6, Brown Winter 2015 Member of USF Tampa, Team 5-6, Brown Winter 2015
USFT-BROWN-W15S5G6
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 30
Past 30 Days: 118
All Time: 3,004
