Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The iHome iP1 was released in July 2009, as the first iHome speaker system meant to be a complete home audio set. This iHome speaker system is equipped with two 4” honeycomb woofers and two 1” dome tweeters on the top corners of the faceplate. It also has a 30-pin iPhone/iPod connector and uses Bongiovi Acoustics Digital Power Station speaker technology, which allows the iHome iP1 to improve its audio quality without needing larger speakers.
The iHome iP1 has had no major recalls and has received favorable reviews.
Identification
The entire device is black with a transparent black-tinted faceplate. The iHome logo is located on the lower left-hand corner of the faceplate, and the Bongiovi DPS Acoustics logo is located on the lower right-hand corner of the faceplate. The iPhone/iPod dock is on the center of the faceplate and has four small command buttons. Directly above the dock, there is a small black bumper knob on which the docked iPhone/iPod can rest. An aux-in jack and component and composite output ports are also located on the back of the iHome iP1.
You can identify your device by the model and serial numbers printed on a black label on the bottom of the audio system.
Additional Information
iHome iP1 Product Page
iHome Troubleshooting
iHome iP1 CNET Review
iHome iP1 Digital Trends Review
iHome iP1 on Amazon
Author
with
Joshua Tran
161 Reputation
1 Guide authored
Cal Poly, Team 20-1, Livingston Fall 2016 Member of Cal Poly, Team 20-1, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G1
4 Members
84 Guides authored
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 62
All Time: 5,093
