iHome iP1 Motherboard Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
87
All Time:
2,558
Comments: 7
1 comment on steps, 6 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Use this guide to replace your iHome iP1's damaged or faulty motherboard. The motherboard is located on the back of your iHome iP1 and is protected by its back cover. Although the motherboard connects all of the electronic parts in the iHome iP1, it is relatively simple to remove.
Tools
    1. iHome iP1 Motherboard Replacement, Back Cover: step 1, image 1 of 1
      • Orient the iHome upside down with the speakers facing away from you.
      Ask FixBot
    2. iHome iP1 Motherboard Replacement: step 2, image 1 of 2 iHome iP1 Motherboard Replacement: step 2, image 2 of 2
      • Remove the four 9.5 mm Phillips #2 screws located on each of the four corners of the iHome's back cover.
      Ask FixBot
    3. iHome iP1 Motherboard Replacement: step 3, image 1 of 1
      • Remove the back cover by grabbing its sides and lifting it off the iHome.
      Ask FixBot
    1. iHome iP1 Motherboard Replacement, Motherboard: step 4, image 1 of 2 iHome iP1 Motherboard Replacement, Motherboard: step 4, image 2 of 2
      • Disconnect all five wire bundles attached to the motherboard by pulling them away from their connection.
      • The order in which the wire bundles are removed does not matter.
      • You may need to remove some black foam tape in order fully disconnect some of the wires.
      Ask FixBot
    2. iHome iP1 Motherboard Replacement: step 5, image 1 of 2 iHome iP1 Motherboard Replacement: step 5, image 2 of 2
      • Unscrew the four 9.5 mm Phillips #2 screws on the four metal brackets located at each corner of the motherboard.
      Ask FixBot
    3. iHome iP1 Motherboard Replacement: step 6, image 1 of 2 iHome iP1 Motherboard Replacement: step 6, image 2 of 2
      • Unscrew the grey 6.0 mm Phillips #1 screw directly above the red, blue, and green component ports.
      Ask FixBot
    4. iHome iP1 Motherboard Replacement: step 7, image 1 of 3 iHome iP1 Motherboard Replacement: step 7, image 2 of 3 iHome iP1 Motherboard Replacement: step 7, image 3 of 3
      • Remove the motherboard from its housing by grabbing it near its edges and carefully pulling it upward.
      Ask FixBot
4 other people completed this guide.
Sachin Shenoi
369 Reputation
2 Guides authored
Cal Poly, Team 20-1, Livingston Fall 2016 Member of Cal Poly, Team 20-1, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G1
4 Members
84 Guides authored
6 Guide Comments
Easy to do,
but where can i buy a new motherboard ?
reagrds
Joerg (ifixit@xyz.logopainter.de)
Joerg Peters - Reply Share
I have the same problem ? Where I can obtain a new motherboard ?
Stefano Antoniutti
anto5657@alice.it
Stefano Antoniutti - Reply Share
Were you able to buy the motherboard?
Rodrigo - Reply Share
Rodrigo
rodrigo@r7criacoes.com.br
i also facing same issue, where can i get new motherboard ?
riyupc123@gmail.com
Riyu PC - Reply Share
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 87
All Time: 2,558
