Up to 20% off select tools
Guides
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background and Identification
Small engines can be found in a variety of vehicles and machines, including lawnmowers, golf carts, and generators. Small engines employ internal combustion technology. This means they are powered by the combustion of a fuel-air mixture after it is compressed by a piston and ignited by a spark plug. The combustion of the fuel-air mixture forces the engine’s piston upwards, which rotates a crankshaft. Through a transmission and drivetrain—basically a collection of gears and other mechanical elements that relay movement—the combustion engine powers the machine it is paired with. Essentially, internal combustion engines convert the fuel they burn into work. This allows the engine to achieve a variety of functions, from spinning a lawnmower blade to propelling a golf cart forward.
Most small engines are powered by a recoil start mechanism, meaning the user pulls a start cord. Pulling the start cord causes the engine to turn just enough for the fuel-air mixture to be initially ignited by the spark plug.
Small engines are notably more compact than full-size engines, saving space but resulting in reduced power output. Small engines have numerous key components, including a fuel tank, carburetor, spark plug, cylinder, piston, crankshaft, flywheel, etc.
Additional Information
Author
with
Geoff Wacker
93,223 Reputation
88 Guides authored
Past 24 Hours: 7
Past 7 Days: 68
Past 30 Days: 359
All Time: 27,825
