Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Briggs & Stratton 190cc 675 Series Push Mower Engine produces 6.75 ft.-lbs. gross torque. The 675 Series Engine is the more powerful version of the standard 650 Engine that Briggs and Stratton usually uses. It has a similar design as the 650, so if you are looking for repair guides to a 650 engine, these will work just as well.
This 1.6-quart gasoline engine features a one-start float carburetor for one-pull starts, a mechanical compression release for quick starting, and a composite camshaft for device longevity. It is equipped with a Lo-Tone muffler that helps the engine run quietly.
Manufacture Date: February 2011
Model #126T02
Identification
The Briggs & Stratton lawn mower engine has a bore of 68.3 mm (2.69 in) and a stroke of 51.8 mm (2.04 in). You can identify the engine by the black plastic cover with a Briggs & Stratton logo printed on a label toward the front. A larger black label on top of the engine also displays the Briggs & Stratton logo, the series number 675 in large red text, and 190 cc printed beneath it in white.
You can find the 11- or 12-digit model number stamped into the metal blower housing, muffler heat shield, or valve cover, often near the spark plug or above the muffler. On some older models, the model number may be printed on a label on the fuel tank.
Additional Information
Official Briggs & Stratton site
Briggs and Stratton Re-Powering Guidelines
Briggs and Stratton 675 on Reddit/lawnmowers
Briggs & Stratton Top 5 Mower Issues and Common Fixes
Briggs and Stratton 675 Series on Amazon
Briggs & Stratton 110000, 120000, 200000 and 210000 Engine Operating & Maintenance Instructions
Briggs & Stratton Quantum 120000, 625–675 Series Operator's Manual (EN, ES, FR)
Briggs & Stratton Quantum 120000, 625–675 Series Operator's Manual (EN, BG, CS, ET, HR, HU, LT, LV, PL, RO, RU, SL)
Briggs & Stratton Quantum 625–725 Series Engine Operator's Manual (EN, ES, FR)
Briggs & Stratton 110000, 120000, 200000 and 210000 Operating & Maintenance Instructions
Briggs & Stratton Quantum Operator's Manual (EN, BG, CS, ET, HR, HU, LT, LV, PL, RO, RU, SL)
Briggs & Stratton 110000/120000/200000/210000 Engine Operating & Maintenance Instructions
Briggs & Stratton Model 120000 625–725 Series Operator’s Manual (EN, DA, DE, EL, ES, FI, FR, IT, NL, NO, PT, SV)
Briggs & Stratton Quantum 120000 Operator's Manual (EN, DA, DE, EL, ES, FI, FR, IT, NL, NO, PT, SV)
Model 120000 Quantum® — керівництво з експлуатації двигуна
Author
with
Tim Wirtz
1,154 Reputation
1 Guide authored
Cal Poly, Team 6-31, Amido Winter 2015 Member of Cal Poly, Team 6-31, Amido Winter 2015
CPSU-AMIDO-W15S6G31
4 Members
72 Guides authored
Past 24 Hours: 15
Past 7 Days: 86
Past 30 Days: 510
All Time: 177,166
