Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Core Engine Series
Kohler categorizes its engines based on their duty cycle and target application, ranging from consumer-grade to extreme-duty commercial units.
  • Command PRO Series: These are the flagship commercial-grade engines designed for high-hour use. They feature full-pressure lubrication, cast-iron cylinder bores, and a heavy-duty air filtration system. They are the "gold standard" for professional landscaping equipment and industrial machinery.
  • 7000 Series: Engineered specifically for residential zero-turn mowers, the 7000 series balances commercial-grade features with consumer-level maintenance. It offers professional-style integrated oil filtration and consistent starting technology for large residential properties.
  • Confidant Series: This is a "prosumer" bridge between the 7000 and the Command PRO. It uses a heavy-duty air cleaner and high-torque inertia drive starters, making it ideal for semi-professional use or homeowners with demanding terrain.
  • Courage Series: Primarily found on entry-to-mid-level riding mowers, this series focuses on smooth operation and vertical-shaft efficiency. While reliable, it is intended for standard residential duty cycles rather than daily commercial use.
Author
with
oldturkey03
867,026 Reputation
123 Guides authored
Global Fixers Member of Global Fixers
Community
74 Members
3,048 Guides authored
Past 24 Hours: 5
Past 7 Days: 16
Past 30 Days: 83
All Time: 424
