Up to 20% off select tools
19 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
GX120UT2
Background and Identification
The Honda General Purpose Motor model GX120UT2 is an air-cooled, four-stroke, overhead-valve engine. It can be used for pressure washers, commercial lawn and garden equipment, tillers and cultivators, generators, construction and industrial equipment, agricultural equipment, small vehicles, and water pumps, among other applications. Without fuel or oil, this engine weighs 29 pounds.
The model GX120UT2 displaces 118 cubic centimeters (cc) and produces a net power output of 3.5-horsepower at a speed of 3,600 revolutions per minute. The GX120UT2 model’s larger sibling, the GX270UT2, produces 8.5-horsepower at 3,600 revolutions per minute. The engine produces a net torque of 5.4 foot-pounds at 2,500 revolutions per minute. It can hold up to 2.1 U.S. quarts (2.1 liters) of gasoline and 0.59 U.S. quarts (0.56 liters) of engine oil. Honda recommends using unleaded 86 octane or higher fuel for this engine.
The GX120UT2 model was sold in five different shaft configurations, the L-type (reduction-type PTO), Q-type (straight-shaft), S-type (metric straight-shaft), T-type (straight-shaft), and AR-type (rammer).
The Honda General Purpose Motor model GX120UT2 can be identified by its red engine cover, a white fuel tank, and a mechanical box with a black cover. The name “Honda” is printed in white font on the side of the engine cover along with the model “GX” in red font and “120” in black font with a white border.
Technical Specifications
Engine Type: Air-cooled 4-stroke OHV
Bore x Stroke: 60 X 42 mm
Displacement: 118 cm3
Net Power Output: 3.5 HP (2.6 kW) @ 3,600 rpm
Net Torque: 5.4 lb-ft (7.3 Nm) @ 2,500 rpm
PTO Shaft Rotation: Counterclockwise (from PTO shaft side)
Compression Ratio: 8.5:1
Lamp/Charge coil options: 25W, 50W
Carburetor: Butterfly
Ignition System: Transistorized magneto
Starting System: Recoil
Lubrication System: Splash
Governor System: Mechanical
Air cleaner: Dual Element
Oil Capacity: 0.59 US qt. (0.56 L)
Fuel Tank Capacity: 2.1 U.S. qts (2.0 liters)
Fuel: Unleaded 86 octane or higher
Dry Weight: 29 lbs. (13.0 kg)
Additional Information
Honda GX120 GX160 GX200 Engine Owner's Manual (EN, FR, ES)
Honda GX120/GX160/GX200 UT2/RT2 Engines Owner's Manual (EN, FR, ES)
Honda GX120/GX160/GX200 Motor Bedienungsanleitung
Honda GX120 · GX160 · GX200 Engine Owner's Manual
Honda GX120UT2/160UT2/200UT2 Engine Service Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 6
Past 7 Days: 38
Past 30 Days: 190
All Time: 9,801
