Up to 20% off select tools
Small Engine Recoil Starter Replacement
Views: 4.3K
View statistics:
Past 24 Hours:
7
Past 7 Days:
38
Past 30 Days:
217
All Time:
4,336
Comments: 0
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 10
10 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will show how to take apart and repair the small engine recoil starter on a lawn mower.
    1. Small Engine Recoil Starter Replacement, Recoil Starter: step 1, image 1 of 1
      • To begin the repair remove the protective casing. (This removal may vary with different lawnmowers.)
      Ask FixBot
    2. Small Engine Recoil Starter Replacement: step 2, image 1 of 1
      • Locate the recoil housing cap.
      Ask FixBot
    3. Small Engine Recoil Starter Replacement: step 3, image 1 of 1
      • Carefully remove the housing cap. (Removal may vary)
      Ask FixBot
    4. Small Engine Recoil Starter Replacement: step 4, image 1 of 1
      • After removing the recoil, unscrew the cap that holds the pulley to the recoil starter housing.
      Ask FixBot
    5. Small Engine Recoil Starter Replacement: step 5, image 1 of 1
      • Untie the knot in the rope and slide it out of the housing.
      Ask FixBot
    6. Small Engine Recoil Starter Replacement: step 6, image 1 of 1
      • With this particular model there is a middle lock piece. Use a socket wrench to unscrew and release the coil.
      Ask FixBot
    7. Small Engine Recoil Starter Replacement: step 7, image 1 of 1
      • Once unscrewed, remove the metal piece which releases the tension on the coil.
      Ask FixBot
    8. Small Engine Recoil Starter Replacement: step 8, image 1 of 1
      • At this point add the new coil to the housing base. Snap the coil into position where the old on was.
      Ask FixBot
5 other people completed this guide.
Author
with
James Marmaud
276 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 38
Past 30 Days: 217
All Time: 4,336
