Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Troubleshooting
Identify what needs to be done to fix your device with the troubleshooting page.
Background
This device was created as an upgrade from previous phones such as the Axxess Executive Display and the IP PhonePlus. It has to ability to place intercom calls, place outside calls, place conference calls, forward calls, and page. There are also many other features that come into play especially when the device is hooked up to a network in an office.
Identification
The Inter-tel 8660 can be identified very easily. There is an Inter-tel label on the front of the phone and a label on the bottom of the device that clearly states the Model Name: 8660. The 8560 model is very similar to the 8660, but the 8660 can be differentiated by a few simple features. The 8660 has additional ports on the back that are used for Internet and power connections, does not support the Off-Hook Voice Announce feature, and does not support the Enhanced Speakerphone Mode feature.
Online Resources
Buy Used on Amazon
The Inter-tel IP 8660 user guide.
Technical support from Inter-tel (now known as Mitel).
If you can't fix your device on your own, there are also repair services offered by Mitel.
Model 8560/8660 User Guide
Model 8560 Display Phone and Model 8660 IP Phone User Guide
Inter-Tel Axxess Model 8560 Phone and Model 8660 IP Phone User Guide
Author
with
Mariano Bautista
19 Reputation
2 Guides authored
Cal Poly, Team 11-24, Maness Winter 2012 Member of Cal Poly, Team 11-24, Maness Winter 2012
CPSU-MANESS-W12S11G24
4 Members
84 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 22
All Time: 5,235
