Inter-tel IP 8660 Internal speaker Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
Past 7 Days:
9
Past 30 Days:
47
All Time:
1,227
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide details the steps to replace the internal speaker of your Inter-tel IP 8660.
Tools
    1. Inter-tel IP 8660 Internal speaker Replacement, Rear Cover: step 1, image 1 of 1
      • Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
      Ask FixBot
    2. Inter-tel IP 8660 Internal speaker Replacement: step 2, image 1 of 3 Inter-tel IP 8660 Internal speaker Replacement: step 2, image 2 of 3 Inter-tel IP 8660 Internal speaker Replacement: step 2, image 3 of 3
      • Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out.
      • 8 mm long
      • 11 mm long
      Ask FixBot
    3. Inter-tel IP 8660 Internal speaker Replacement: step 3, image 1 of 1
      • Lift up the back cover and set it aside.
      Ask FixBot
    1. Inter-tel IP 8660 Internal speaker Replacement, Internal speaker: step 4, image 1 of 1
      • While holding down the motherboard, gently pull the wire harness connecting the speaker to the motherboard until it comes free.
      Ask FixBot
    2. Inter-tel IP 8660 Internal speaker Replacement: step 5, image 1 of 1
      • Lift up the speaker.
      Ask FixBot
Megan Buck
15 Reputation
1 Guide authored
Cal Poly, Team 11-24, Maness Winter 2012 Member of Cal Poly, Team 11-24, Maness Winter 2012
CPSU-MANESS-W12S11G24
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 47
All Time: 1,227
