Inter-tel IP 8660 Rear Cover Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
6
Past 30 Days:
35
All Time:
896
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide details the steps to take off the rear cover of your Inter-tel IP 8660.
Tools
    1. Inter-tel IP 8660 Rear Cover Replacement, Rear Cover: step 1, image 1 of 1
      • Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
      Ask FixBot
    2. Inter-tel IP 8660 Rear Cover Replacement: step 2, image 1 of 3 Inter-tel IP 8660 Rear Cover Replacement: step 2, image 2 of 3 Inter-tel IP 8660 Rear Cover Replacement: step 2, image 3 of 3
      • Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out.
      • 8 mm long
      • 11 mm long
      Ask FixBot
    3. Inter-tel IP 8660 Rear Cover Replacement: step 3, image 1 of 1
      • Lift up the back cover and set it aside.
      Ask FixBot
Mariano Bautista
19 Reputation
2 Guides authored
Cal Poly, Team 11-24, Maness Winter 2012 Member of Cal Poly, Team 11-24, Maness Winter 2012
CPSU-MANESS-W12S11G24
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 6
Past 30 Days: 35
All Time: 896
