Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Spudger4.9
Introduction
Go to step 1 ↓This guide details the steps to taking off the LCD screen of your Inter-tel IP 8660.
Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
While holding down the motherboard, gently pull the wire harness connecting the speaker to the motherboard until it comes free.
Lift up the motherboard out of its housing in the front cover of the phone.
Set the front cover and button pads aside.
Push the black clip holding the ribbon cable out of its casing using the plastic opening tool.
This is done using the spudger to lift one side out of its housing.
Reposition the spudger to the other side of the black clip and push it flush with the other end.
Note: The black clip pushes out of the housing and does not come completely loose.
