Inter-tel IP 8660 Motherboard Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
6
Past 30 Days:
28
All Time:
1,521
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
    1. Inter-tel IP 8660 Motherboard Replacement, Rear Cover: step 1, image 1 of 1
      • Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
      Ask FixBot
    2. Inter-tel IP 8660 Motherboard Replacement: step 2, image 1 of 3 Inter-tel IP 8660 Motherboard Replacement: step 2, image 2 of 3 Inter-tel IP 8660 Motherboard Replacement: step 2, image 3 of 3
      • Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out.
      • 8 mm long
      • 11 mm long
      Ask FixBot
    3. Inter-tel IP 8660 Motherboard Replacement: step 3, image 1 of 1
      • Lift up the back cover and set it aside.
      Ask FixBot
    1. Inter-tel IP 8660 Motherboard Replacement, Internal speaker: step 4, image 1 of 1
      • While holding down the motherboard, gently pull the wire harness connecting the speaker to the motherboard until it comes free.
      Ask FixBot
    2. Inter-tel IP 8660 Motherboard Replacement: step 5, image 1 of 1
      • Lift up the speaker.
      Ask FixBot
    1. Inter-tel IP 8660 Motherboard Replacement, LCD Screen: step 6, image 1 of 3 Inter-tel IP 8660 Motherboard Replacement, LCD Screen: step 6, image 2 of 3 Inter-tel IP 8660 Motherboard Replacement, LCD Screen: step 6, image 3 of 3
      • Lift up the motherboard out of its housing in the front cover of the phone.
      • Set the front cover and button pads aside.
      Ask FixBot
    2. Inter-tel IP 8660 Motherboard Replacement: step 7, image 1 of 3 Inter-tel IP 8660 Motherboard Replacement: step 7, image 2 of 3 Inter-tel IP 8660 Motherboard Replacement: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • Using tweezers, pinch the highlighted connective clips together and depress. Start with the clips in the middle of the motherboard first.
      • Note: There are four clips, one at each corner of the LCD screen.
      Ask FixBot
    3. Inter-tel IP 8660 Motherboard Replacement: step 8, image 1 of 1
      • Flip the motherboard over so that the LCD screen is facing upward.
      Ask FixBot
    4. Inter-tel IP 8660 Motherboard Replacement: step 9, image 1 of 2 Inter-tel IP 8660 Motherboard Replacement: step 9, image 2 of 2
      • Push the black clip holding the ribbon cable out of its casing using the plastic opening tool.
      • This is done using the spudger to lift one side out of its housing.
      • Reposition the spudger to the other side of the black clip and push it flush with the other end.
      • Note: The black clip pushes out of the housing and does not come completely loose.
      Ask FixBot
    5. Inter-tel IP 8660 Motherboard Replacement: step 10, image 1 of 3 Inter-tel IP 8660 Motherboard Replacement: step 10, image 2 of 3 Inter-tel IP 8660 Motherboard Replacement: step 10, image 3 of 3
      • Pull gently on the ribbon cable so that it comes loose from the black clip.
      Ask FixBot
Mariano Bautista
19 Reputation
2 Guides authored
Cal Poly, Team 11-24, Maness Winter 2012 Member of Cal Poly, Team 11-24, Maness Winter 2012
CPSU-MANESS-W12S11G24
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 6
Past 30 Days: 28
All Time: 1,521
