Inter-tel IP 8660 Handset Back Cover Replacement
    1. Inter-tel IP 8660 Handset Back Cover Replacement, Handset Back Cover: step 1, image 1 of 1
      • Disconnect the phone cord from the handset jack.
      Ask FixBot
    2. Inter-tel IP 8660 Handset Back Cover Replacement: step 2, image 1 of 2 Inter-tel IP 8660 Handset Back Cover Replacement: step 2, image 2 of 2
      • Unscrew the two black screws (8 mm long) located in the middle of the handset using #1 Phillips head.
      Ask FixBot
    3. Inter-tel IP 8660 Handset Back Cover Replacement: step 3, image 1 of 2 Inter-tel IP 8660 Handset Back Cover Replacement: step 3, image 2 of 2
      • Pry the back cover off the headset using a spudger. It is best to pry at the top of the handset.
      Ask FixBot
Cal Poly, Team 11-24, Maness Winter 2012 Member of Cal Poly, Team 11-24, Maness Winter 2012
CPSU-MANESS-W12S11G24
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 37
All Time: 996
