Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Checking Cables and Wires
  1. Check the terminal for tightness.
  2. Check terminals and wires for corrosion from battery electrolyte, etc.
  3. Check terminals and wires for open circuits.
  4. Check wire insulation and coating for damage, cracks, and degrading.
  5. Check the conductive parts of terminals for contact with other metallic parts (vehicle body and other parts).
  6. Check grounded parts to verify that there is complete continuity between their attaching bolt(s) and the vehicle''s body.
  7. Check for incorrect wiring.
  8. Check that the wiring is so clamped to the prevent contact with sharp corners of the vehicle body, etc. or hot parts (exhaust manifold, etc.)
  9. Check that the wiring is clamped firmly to provide enough clearance from the fan pulley, fan belt and other rotating or moving parts.
  10. Check that the wiring has a little space so that it can vibrate between fixed and moving parts such as the vehicle body and the engine.
Author
with
Matt Zieminski
50,478 Reputation
28 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 47
Past 7 Days: 253
Past 30 Days: 938
All Time: 30,826
