Hyundai Accent Ignition Coils Replacement
    1. Hyundai Accent Ignition Coils Replacement, Remove the engine cover: step 1, image 1 of 2 Hyundai Accent Ignition Coils Replacement, Remove the engine cover: step 1, image 2 of 2
      • Grasp the engine cover by the front edge.
      • Give it a firm yank upward.
      Ask FixBot
    2. Hyundai Accent Ignition Coils Replacement: step 2, image 1 of 2 Hyundai Accent Ignition Coils Replacement: step 2, image 2 of 2
      • Grab the rear edge of the cover.
      • Yank it upward.
      Ask FixBot
    3. Hyundai Accent Ignition Coils Replacement: step 3, image 1 of 1
      • The engine cover has been removed.
      Ask FixBot
    1. Hyundai Accent Ignition Coils Replacement, Ignition Coils: step 4, image 1 of 2 Hyundai Accent Ignition Coils Replacement, Ignition Coils: step 4, image 2 of 2
      • We're starting with the #4 cylinder here, but it doesn't actually matter where you start.
      • Slide the gray locking clip away from the coil to unlock the connector.
      Ask FixBot
    2. Hyundai Accent Ignition Coils Replacement, Unplug the coils: step 5, image 1 of 2 Hyundai Accent Ignition Coils Replacement, Unplug the coils: step 5, image 2 of 2
      • With the locking tab released, grasp the connector and pull it straight off.
      Ask FixBot
    3. Hyundai Accent Ignition Coils Replacement: step 6, image 1 of 3 Hyundai Accent Ignition Coils Replacement: step 6, image 2 of 3 Hyundai Accent Ignition Coils Replacement: step 6, image 3 of 3
      • Moving along to cylinder #3, release the connector lock and unplug the coil.
      Ask FixBot
    4. Hyundai Accent Ignition Coils Replacement: step 7, image 1 of 3 Hyundai Accent Ignition Coils Replacement: step 7, image 2 of 3 Hyundai Accent Ignition Coils Replacement: step 7, image 3 of 3
      • Repeat for cylinder #2.
      Ask FixBot
    5. Hyundai Accent Ignition Coils Replacement: step 8, image 1 of 3 Hyundai Accent Ignition Coils Replacement: step 8, image 2 of 3 Hyundai Accent Ignition Coils Replacement: step 8, image 3 of 3
      • And, as you probably guessed, we finish up with cylinder #1.
      Ask FixBot
    6. Hyundai Accent Ignition Coils Replacement, Remove the retaining fasteners: step 9, image 1 of 3 Hyundai Accent Ignition Coils Replacement, Remove the retaining fasteners: step 9, image 2 of 3 Hyundai Accent Ignition Coils Replacement, Remove the retaining fasteners: step 9, image 3 of 3
      • Using a 10 mm socket, remove the bolt securing the #4 coil.
      • For reassembly, the tightening torque is 9.8 ~ 11.8 Nm (1.0 ~ 1.2 kgf.m, 7.2 ~ 8.7 lb-ft)
      • Note that most non-professional torque wrenches are not very accurate below about 15 ft/lbs, so it is recommended to use an in/lb wrench, in which case the torque settings to use would be from 86 to 104 lb-in.
      Ask FixBot
    7. Hyundai Accent Ignition Coils Replacement: step 10, image 1 of 2 Hyundai Accent Ignition Coils Replacement: step 10, image 2 of 2
      • Repeat for cylinder #3.
      Ask FixBot
    8. Hyundai Accent Ignition Coils Replacement: step 11, image 1 of 2 Hyundai Accent Ignition Coils Replacement: step 11, image 2 of 2
      • Moving along to cylinder #2, rinse and repeat.
      Ask FixBot
    9. Hyundai Accent Ignition Coils Replacement: step 12, image 1 of 2 Hyundai Accent Ignition Coils Replacement: step 12, image 2 of 2
      • And we finish up back on cylinder #1.
      Ask FixBot
    10. Hyundai Accent Ignition Coils Replacement, Remove the coils: step 13, image 1 of 2 Hyundai Accent Ignition Coils Replacement, Remove the coils: step 13, image 2 of 2
      • Moving back to the #4 cylinder, grasp the coil and pull straight up to remove it.
      Ask FixBot
    11. Hyundai Accent Ignition Coils Replacement: step 14, image 1 of 2 Hyundai Accent Ignition Coils Replacement: step 14, image 2 of 2
      • Likewise for the #3 coil.
      Ask FixBot
    12. Hyundai Accent Ignition Coils Replacement: step 15, image 1 of 2 Hyundai Accent Ignition Coils Replacement: step 15, image 2 of 2
      • We pull the #2 coil.
      Ask FixBot
    13. Hyundai Accent Ignition Coils Replacement: step 16, image 1 of 2 Hyundai Accent Ignition Coils Replacement: step 16, image 2 of 2
      • And for our grand finale, we remove the coil from cylinder #1.
      Ask FixBot
    14. Hyundai Accent Ignition Coils Replacement: step 17, image 1 of 1
      • The ignition coils have been removed.
      Ask FixBot
Jerry Wheeler
100,386 Reputation
92 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 101
All Time: 307
