Hyundai Accent Crankshaft Position Sensor Replacement
  1. Hyundai Accent Crankshaft Position Sensor Replacement, Unplug the sensor: step 1, image 1 of 3 Hyundai Accent Crankshaft Position Sensor Replacement, Unplug the sensor: step 1, image 2 of 3 Hyundai Accent Crankshaft Position Sensor Replacement, Unplug the sensor: step 1, image 3 of 3
    • The plug can be reached from below or above, but is difficult to see from either angle. The photos here were taken with the throttle body removed for clarity. It is located under the intake manifold next to the starter motor.
    • Firmly press the latch on the connector.
    • Pull the connector off.
    Ask FixBot
  2. Hyundai Accent Crankshaft Position Sensor Replacement, Dismount the connector: step 2, image 1 of 1
    • It may take a bit of force, but the connector is mounted on a metal bracket and can be removed by pulling up on it.
    Ask FixBot
  3. Hyundai Accent Crankshaft Position Sensor Replacement, Locate the CKPS: step 3, image 1 of 1
    • The crankshaft position sensor can be seen from under the car. The front of the car is at the bottom of the picture and is framed by the engine's lower shields. The oil filter is plainly visible on the right.
    Ask FixBot
  4. Hyundai Accent Crankshaft Position Sensor Replacement, Unbolt the CKPS: step 4, image 1 of 3 Hyundai Accent Crankshaft Position Sensor Replacement, Unbolt the CKPS: step 4, image 2 of 3 Hyundai Accent Crankshaft Position Sensor Replacement, Unbolt the CKPS: step 4, image 3 of 3
    • Here we see a closer picture of the sensor and its retaining bolt.
    • Use a 10 mm socket to remove the bolt.
    Ask FixBot
  5. Hyundai Accent Crankshaft Position Sensor Replacement, Disconnect the wire hanger: step 5, image 1 of 2 Hyundai Accent Crankshaft Position Sensor Replacement, Disconnect the wire hanger: step 5, image 2 of 2
    • Here you can see the wire hanger that secures the CKPS wire to a bracket.
    • Normally these can be removed with needle nose pliers, but the position here makes that impractical. I used a small right angle pick to compress one side then the other, while maintaining tension on it.
    Ask FixBot
  6. Hyundai Accent Crankshaft Position Sensor Replacement, Remove the CKPS: step 6, image 1 of 2 Hyundai Accent Crankshaft Position Sensor Replacement, Remove the CKPS: step 6, image 2 of 2
    • The sensor can now be removed by pulling it straight out.
    Ask FixBot
Apply engine oil to the O-ring before installing the sensor.
Torque specifications: 7.8 - 11.8 N.m / 0.8 - 1.2 kgf.m / 5.8 - 8.7 lb-ft
Note that most torque wrenches specified in foot-pounds are not very accurate at low settings like these. If possible, use a wrench calibrated in inch-pounds. Use 70-105 lb-in to torque.
Jerry Wheeler
98,239 Reputation
92 Guides authored
0 Guide Comments
Past 24 Hours: 23
Past 7 Days: 165
Past 30 Days: 802
All Time: 2,535
