No sound from radio
no sound from radio. Checked fuses and they are ok. It started being an intermittent problem, but now there is no sound despite visual display working..
Hi @aussiescot
Have you tried using different audio inputs besides radio (AM/FM) e.g. CD, Bluetooth, USB, Aux input to check whether it is a audio out problem (all inputs - no audio heard in speakers) or if it's just a radio (AM/FM) problem (all other inputs OK - audio heard in speakers)?
If it's just a radio problem it could be an antenna problem or a problem with the radio circuit in the unit. Not sure if the following will work but try an auto scan of radio stations to see if the unit indicates that it is picking up the radio signals from the various AM and FM stations in your location. You won't hear anything but if the unit pauses on each known station before moving on with the scan this indicates that the antenna is OK.
If there's no audio heard from any input type then it could be a faulty speaker cable connection on the back of the unit (all the speakers are wired to the one harness cable plug) or a problem in the unit itself.
Here's a link from the service manual showing how to remove the entertainment unit which will allow access the cables in the rear of the unit so that you can check if the cables are securely connected.
Here's the system wiring diagram that may also help.
Since the display works and fuses are intact, the no-sound issue is likely caused by a failed factory amplifier, a software glitch, or a malfunctioning audio module. The intermittent nature progressing to total failure strongly points toward a dying component or loose connection.
Key Troubleshooting Steps:
If the amplifier is receiving power but not producing sound, it likely needs replacement.
Past 24 Hours: 7
Past 7 Days: 22
Past 30 Days: 74
All Time: 373
2 Comments
Hi @aussiescot
What year is the vehicle?
by jayeff
It’s a 2013 model
by Aussiescot
