Up to 20% off select tools
Guides
Ask a Question
There are no questions. Be the first to ask a question!
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Troubleshooting
Track down common problems with your HTC Maple 100 at our troubleshooting page HTC Maple 100 Troubleshooting
Background
The HTC Maple 100 is also known under the name HTC Snap S521. It was released in May 2009 and is no longer in production. The phone runs on the Microsoft Window Mobile 6.1 operating system. The display diagonal is 2.4 inches with a resolution of 320 X 240 pixels. The camera is 1.9 Megapixels with a 1X optical zoom. The battery has a capacity of 1500 mAh.
Identification
To properly identify your device, take the back cover off and remove the battery. Above the directions on how to remove the battery and sim card, it should say "MAPL100 5VDC 1A FCC ID: NM8MAPL100 Made in Taiwan."
The phone is 61.5 X 116.5 X12 millimeters and is 120 grams with the battery.
Author
with
Andrew Van Meter
24 Reputation
3 Guides authored
Cal Poly, Team 20-29, Maness Fall 2011 Member of Cal Poly, Team 20-29, Maness Fall 2011
CPSU-MANESS-F11S20G29
4 Members
108 Guides authored
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 33
All Time: 3,777
