HTC Maple 100 Internal Ear Speaker Replacement
    1. HTC Maple 100 Internal Ear Speaker Replacement, Battery: step 1, image 1 of 1
      • First remove the back cover of your phone to expose the battery.
      Ask FixBot
    2. HTC Maple 100 Internal Ear Speaker Replacement: step 2, image 1 of 1
      • Turn the phone over.
      • Push forward on the battery with your thumb.
      Ask FixBot
    3. HTC Maple 100 Internal Ear Speaker Replacement: step 3, image 1 of 2 HTC Maple 100 Internal Ear Speaker Replacement: step 3, image 2 of 2
      • Take the battery out by lifting it upwards.
      • When reassembling, make sure that the battery contacts match up.
      Ask FixBot
    1. HTC Maple 100 Internal Ear Speaker Replacement, Back Panel: step 4, image 1 of 2 HTC Maple 100 Internal Ear Speaker Replacement, Back Panel: step 4, image 2 of 2
      • Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone.
      Ask FixBot
    2. HTC Maple 100 Internal Ear Speaker Replacement: step 5, image 1 of 1
      • Remove the two 4.3mm Phillips #00 screws that secure the back panel to the rest of the phone.
      Ask FixBot
    3. HTC Maple 100 Internal Ear Speaker Replacement: step 6, image 1 of 3 HTC Maple 100 Internal Ear Speaker Replacement: step 6, image 2 of 3 HTC Maple 100 Internal Ear Speaker Replacement: step 6, image 3 of 3
      • Insert the plastic opening tool along the seams at different points to it pry the clips off.
      • This may require a bit of force. The USB port cover may fall off in this step.
      Ask FixBot
    1. HTC Maple 100 Internal Ear Speaker Replacement, Motherboard: step 7, image 1 of 2 HTC Maple 100 Internal Ear Speaker Replacement, Motherboard: step 7, image 2 of 2
      • Remove the one 3.3mm Phillips #00 screw.
      Ask FixBot
    2. HTC Maple 100 Internal Ear Speaker Replacement: step 8, image 1 of 2 HTC Maple 100 Internal Ear Speaker Replacement: step 8, image 2 of 2
      • Use your finger or the plastic opening tool to unclip the board.
      • Be aware of the ribbon cable connected to the motherboard inside the phone.
      Ask FixBot
    3. HTC Maple 100 Internal Ear Speaker Replacement: step 9, image 1 of 2 HTC Maple 100 Internal Ear Speaker Replacement: step 9, image 2 of 2
      • Peel off the yellow piece of tape from the phone.
      Ask FixBot
    4. HTC Maple 100 Internal Ear Speaker Replacement: step 10, image 1 of 3 HTC Maple 100 Internal Ear Speaker Replacement: step 10, image 2 of 3 HTC Maple 100 Internal Ear Speaker Replacement: step 10, image 3 of 3
      • Flip up the retaining flap with your fingernail or a plastic opening tool.
      • Pull on the ribbon cable gently with your fingers.
      Ask FixBot
    5. HTC Maple 100 Internal Ear Speaker Replacement: step 11, image 1 of 2 HTC Maple 100 Internal Ear Speaker Replacement: step 11, image 2 of 2
      • Split apart the motherboard and front panel.
      • Remove the other yellow piece of tape off of the end of the ribbon cable.
      Ask FixBot
    6. HTC Maple 100 Internal Ear Speaker Replacement: step 12, image 1 of 2 HTC Maple 100 Internal Ear Speaker Replacement: step 12, image 2 of 2
      • Gently pull on the ribbon cable to separate the motherboard.
      Ask FixBot
    1. HTC Maple 100 Internal Ear Speaker Replacement, Internal Ear Speaker: step 13, image 1 of 1
      • Locate the internal speaker at the top center of the phone.
      Ask FixBot
    2. HTC Maple 100 Internal Ear Speaker Replacement: step 14, image 1 of 2 HTC Maple 100 Internal Ear Speaker Replacement: step 14, image 2 of 2
      • Using the plastic opening tool, carefully pry out the internal speaker.
      Ask FixBot
Alyssa Thompson
11 Reputation
2 Guides authored
Cal Poly, Team 20-29, Maness Fall 2011 Member of Cal Poly, Team 20-29, Maness Fall 2011
CPSU-MANESS-F11S20G29
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 29
All Time: 1,213
