Up to 20% off select tools
HTC Maple 100 LCD Screen Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
Past 7 Days:
6
Past 30 Days:
16
All Time:
1,474
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Be careful with the LCD screen. It is fragile.
    1. HTC Maple 100 LCD Screen Replacement, Battery: step 1, image 1 of 1
      • First remove the back cover of your phone to expose the battery.
      Ask FixBot
    2. HTC Maple 100 LCD Screen Replacement: step 2, image 1 of 1
      • Turn the phone over.
      • Push forward on the battery with your thumb.
      Ask FixBot
    3. HTC Maple 100 LCD Screen Replacement: step 3, image 1 of 2 HTC Maple 100 LCD Screen Replacement: step 3, image 2 of 2
      • Take the battery out by lifting it upwards.
      • When reassembling, make sure that the battery contacts match up.
      Ask FixBot
    1. HTC Maple 100 LCD Screen Replacement, Back Panel: step 4, image 1 of 2 HTC Maple 100 LCD Screen Replacement, Back Panel: step 4, image 2 of 2
      • Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone.
      Ask FixBot
    2. HTC Maple 100 LCD Screen Replacement: step 5, image 1 of 1
      • Remove the two 4.3mm Phillips #00 screws that secure the back panel to the rest of the phone.
      Ask FixBot
    3. HTC Maple 100 LCD Screen Replacement: step 6, image 1 of 3 HTC Maple 100 LCD Screen Replacement: step 6, image 2 of 3 HTC Maple 100 LCD Screen Replacement: step 6, image 3 of 3
      • Insert the plastic opening tool along the seams at different points to it pry the clips off.
      • This may require a bit of force. The USB port cover may fall off in this step.
      Ask FixBot
    1. HTC Maple 100 LCD Screen Replacement, Motherboard: step 7, image 1 of 2 HTC Maple 100 LCD Screen Replacement, Motherboard: step 7, image 2 of 2
      • Remove the one 3.3mm Phillips #00 screw.
      Ask FixBot
    2. HTC Maple 100 LCD Screen Replacement: step 8, image 1 of 2 HTC Maple 100 LCD Screen Replacement: step 8, image 2 of 2
      • Use your finger or the plastic opening tool to unclip the board.
      • Be aware of the ribbon cable connected to the motherboard inside the phone.
      Ask FixBot
    3. HTC Maple 100 LCD Screen Replacement: step 9, image 1 of 2 HTC Maple 100 LCD Screen Replacement: step 9, image 2 of 2
      • Peel off the yellow piece of tape from the phone.
      Ask FixBot
    4. HTC Maple 100 LCD Screen Replacement: step 10, image 1 of 3 HTC Maple 100 LCD Screen Replacement: step 10, image 2 of 3 HTC Maple 100 LCD Screen Replacement: step 10, image 3 of 3
      • Flip up the retaining flap with your fingernail or a plastic opening tool.
      • Pull on the ribbon cable gently with your fingers.
      Ask FixBot
    5. HTC Maple 100 LCD Screen Replacement: step 11, image 1 of 2 HTC Maple 100 LCD Screen Replacement: step 11, image 2 of 2
      • Split apart the motherboard and front panel.
      • Remove the other yellow piece of tape off of the end of the ribbon cable.
      Ask FixBot
    6. HTC Maple 100 LCD Screen Replacement: step 12, image 1 of 2 HTC Maple 100 LCD Screen Replacement: step 12, image 2 of 2
      • Gently pull on the ribbon cable to separate the motherboard.
      Ask FixBot
    1. HTC Maple 100 LCD Screen Replacement, LCD Screen: step 13, image 1 of 3 HTC Maple 100 LCD Screen Replacement, LCD Screen: step 13, image 2 of 3 HTC Maple 100 LCD Screen Replacement, LCD Screen: step 13, image 3 of 3
      • Pry the LCD screen out by using the plastic opening tool or your fingers.
      Ask FixBot
Author
with
Nick
6 Reputation
3 Guides authored
Cal Poly, Team 20-29, Maness Fall 2011 Member of Cal Poly, Team 20-29, Maness Fall 2011
CPSU-MANESS-F11S20G29
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 16
All Time: 1,474
