Up to 20% off select tools
Guides
Documents
Parts
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
Phantom 3 Standard Remote Controller
Background
The DJI Phantom 3 Standard is an entry-level ready-to-fly quadcopter drone with a built-in camera. It was introduced as a more budget-friendly camera drone after the Phantom 3 Advanced and Professional drones were released. The Standard model was sold at USD $799 in the United States, which is several hundred dollars less than the Professional and Advanced models. The camera captures 2.7K-resolution video that is stabilized by an integrated three-axis gimbal.
The Phantom 3 Standard’s remote control includes a 2600 mAh Lithium-Polymer battery. Under the American Federal Communications Commission (FCC), the Phantom 3 Standard’s remote control has a maximum transmission distance of 1000 meters for an outdoor and unobstructed environment with the aircraft at 400 feet (120 meters). In Europe, the remote control has a maximum transmission distance of 500 meters. The remote control also includes a mobile device holder for tablets and smartphones. It includes a Micro USB charging port.
Identification
The Phantom 3 Standard can be identified by its white plastic shell, typical of DJI quadcopters. This model measures 350mm across diagonally and features red stripes on each of the booms. It has an auto-leveling camera mount (also known as a gimbal) under the main airframe. Behind the gimbal, there is also a vision positioning system mounted under the body.
Technical Specifications
Operating Frequency: 5.725 - 5.825 GHz, 922.7 - 927.7 MHz (Japan)
Max Transmission Distance:
  • FCC: 1000 m
  • CE: 500 m
  • (outdoors and unobstructed, aircraft's altitude at 400 feet (120 m))
Operating Temperature Range: 32° to 104°F (0° to 40°C)
Battery: 2600 mAh LiPo 18650
Transmitter Power (EIRP):
  • FCC: 19 dBm
  • CE: 14 dBm
  • MIC: 10 dBm
Operating Current/Voltage: 600 mA@3.7V
Mobile Device Holder: Tablets and smartphones
Charging Port: Micro USB
Additional Information
Phantom 3 Standard User Manual V1.0
Author
with
Jeff Stephens
281,727 Reputation
0 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 65
All Time: 3,239
