DJI Phantom 3 Standard Remote Controller Battery Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
Past 7 Days:
26
Past 30 Days:
96
All Time:
1,295
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will be used to open the DJI Phantom 3 Standard Remote Controller to access and change the battery. If your controller isn't charging properly, check out this troubleshooting page before continuing onto the repair guide. Step 3 should be handled carefully to avoid damage to the connection between the battery and the connection port.
Parts
Tools
    1. DJI Phantom 3 Standard Remote Controller Battery Replacement, Battery: step 1, image 1 of 2 DJI Phantom 3 Standard Remote Controller Battery Replacement, Battery: step 1, image 2 of 2
      • Position the controller so the back is facing up and the joysticks are resting on the table.
      • Remove the four 11 mm screws that secure the back plate using a Phillips #0 screwdriver.
      • Remove the back plate, being mindful of the wires still connected to the device.
      Ask FixBot
    2. DJI Phantom 3 Standard Remote Controller Battery Replacement: step 2, image 1 of 2 DJI Phantom 3 Standard Remote Controller Battery Replacement: step 2, image 2 of 2
      • Remove the two 8 mm screws securing the battery to the controller using a JIS #00 screwdriver.
      Ask FixBot
    3. DJI Phantom 3 Standard Remote Controller Battery Replacement: step 3, image 1 of 3 DJI Phantom 3 Standard Remote Controller Battery Replacement: step 3, image 2 of 3 DJI Phantom 3 Standard Remote Controller Battery Replacement: step 3, image 3 of 3
      • Use the nylon-tipped tweezers to detach the three-prong battery attachment that connects the battery to the motherboard.
      • Remove the battery.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 26
Past 30 Days: 96
All Time: 1,295
