DJI Phantom 3 Standard Remote Controller Antenna Replacement
  1. DJI Phantom 3 Standard Remote Controller Antenna Replacement, Antenna: step 1, image 1 of 2 DJI Phantom 3 Standard Remote Controller Antenna Replacement, Antenna: step 1, image 2 of 2
    • Position the controller so the back is facing up and the joysticks are resting on the table.
    • Remove the four 11 mm screws that secure the back plate using a JIS #0 screwdriver.
    • Remove the back plate, being mindful of the wires still connected to the device.
    Ask FixBot
  2. DJI Phantom 3 Standard Remote Controller Antenna Replacement: step 2, image 1 of 2 DJI Phantom 3 Standard Remote Controller Antenna Replacement: step 2, image 2 of 2
    • Use a spudger to pry the gray antenna wire from the glue.
    • There is a small metal piece latched in and should be removed from its place as well.
    • While a plastic spudger can be used, the attachment is secure. A metal spudger may produce better results.
    Ask FixBot
  3. DJI Phantom 3 Standard Remote Controller Antenna Replacement: step 3, image 1 of 1
    • Push the wire up to the antenna.
    Ask FixBot
  4. DJI Phantom 3 Standard Remote Controller Antenna Replacement: step 4, image 1 of 1
    • Squeeze and twist the outer antenna attachment to unlatch it from its place.
    • Remove the antenna.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 73
All Time: 729
