DJI Phantom 3 Standard Remote Controller Joysticks Replacement
  1. DJI Phantom 3 Standard Remote Controller Joysticks Replacement, Joysticks: step 1, image 1 of 2 DJI Phantom 3 Standard Remote Controller Joysticks Replacement, Joysticks: step 1, image 2 of 2
    • Position the controller so the back is facing up and the joysticks are resting on the table.
    • Remove the four 11 mm screws that secure the back plate using a JIS #0 screwdriver.
    • Remove the back plate, being mindful of the wires still connected to the device.
    Ask FixBot
  2. DJI Phantom 3 Standard Remote Controller Joysticks Replacement: step 2, image 1 of 1
    • On the inside of the controller, remove the four 11 mm screws that cover the base housing of the joystick.
    Ask FixBot
  3. DJI Phantom 3 Standard Remote Controller Joysticks Replacement: step 3, image 1 of 3 DJI Phantom 3 Standard Remote Controller Joysticks Replacement: step 3, image 2 of 3 DJI Phantom 3 Standard Remote Controller Joysticks Replacement: step 3, image 3 of 3
    • Inside the base housing, remove the two 9 mm screws that secure the joystick brace piece on both the left and right side of the stick.
    • Remove the braces on the left and right sides of the joystick to reach the circuit board piece on the left.
    • Detach the circuit board piece.
    Ask FixBot
  4. DJI Phantom 3 Standard Remote Controller Joysticks Replacement: step 4, image 1 of 2 DJI Phantom 3 Standard Remote Controller Joysticks Replacement: step 4, image 2 of 2
    • Separate the other circuit board piece from the joystick connection using a plastic spudger.
    • The circuit board is wired through glue. If the plastic spudger is unable to pry the glue off, use the metal spudger as a last resort.
    • Take the joystick module itself and remove the four 8 mm screws that connect the joystick to the housing.
    • Unscrew the thumb stick from the module if a replacement is not needed.
    Ask FixBot
  5. DJI Phantom 3 Standard Remote Controller Joysticks Replacement: step 5, image 1 of 1
    • Remove the joystick.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 28
All Time: 405
