Camera will not turn on
The camera doesn't seem to be able to turn on.
Bad power button
Before delving into the guts of your camera, try holding down the power button for several seconds to see if the camera will turn on.
Drained/bad battery
If your camera still won't turn on, try charging the battery again. If this doesn't work, you might have a bad battery that needs replacing. Refer to the Battery Installation Guide for the steps in replacing the battery.
Bad display
It is possible nothing is happening because the display is bad. Check to see if the power indicator LED is on. If the LED is on, you might have a faulty LCD screen. Use the LCD Repair Guide to replace the display.
Bad motherboard
If all other possibilities have been ruled out, the camera may have a faulty motherboard. Look to the Motherboard Repair Guide for instructions how to replace the motherboard.
Lens won't open/close
The lens is stuck in the open or closed position.
Clogged lens
Attempt to clean any dirt or debris that may be obstructing the lens cover.
Drained battery
Try charging the battery and then see if the lens will open or close.
Broken gears or motor mounts
If the battery is charged and there is no visible dirt clogging the lens, the gears or motor mounts may need to be replaced. Unfortunately, the lens of this model can not be disassembled and thus must be completely replaced. See the Lens Repair Guide.
No flash
The flash won't activate automatically.
Flash is turned off
Make sure the flash is toggled in your camera settings. It may have gotten switched off.
Drained battery
The battery may not have enough power to use the flash. Try charging the battery. If it still does not flash, you might need to replace the battery.
Broken flash
If the above solutions do not work, the flash may be physically broken. See Flash Repair Guide to replace the flash.
Camera will not take pictures
The camera will not save or take anymore pictures.
Full memory
Your memory card might be filled to capacity. Try replacing it with another memory card or emptying it by transferring the photos to a computer.
Locked memory card
Some memory cards can be "locked" so you can't interact with them. Remove the memory card and make sure it is unlocked. There should be a switch on the memory card that will indicate whether it is locked.
Computer does not detect the camera
You connected the camera to the computer, but the computer doesn't say it is.
Camera if off
The camera should be on before the computer will detect it. Make sure it is on when you connect it.
Drained battery
Charge the battery while it is plugged into the computer. The computer should detect the camera if it has sufficient charge.
Defective USB cord
Try using a replacement cord to connect the camera and the computer.
Faulty motherboard
If none of the above fixed it, the motherboard might need to be replaced. See the Motherboard Repair Guide for how to do this.
Display has been damaged
The camera's display is visibly cracked or is not displaying properly.
Cracked or scratched display screen
The outer cover may just be damaged. If so, just replace the back casing using the Casing Repair Guide.
Malfunctioning Display
If the LCD is not working correctly or is damaged, it needs to either be reconnected or replaced entirely. Refer to the LCD Repair Guide for instructions on how to do this.
Top button does not work
No matter how hard you press, the button just won't respond.
Dirt or dust in button
Spray compressed air on the top button in question to remove dust and other particles that may have collected in it.
Broken button
The top button might just be broken. Use the Button Repair Guide to fix it.
Robert Potter
41 Reputation
1 Guide authored
Cal Poly, Team 17-25, Amido Spring 2012 Member of Cal Poly, Team 17-25, Amido Spring 2012
CPSU-AMIDO-S12S17G25
4 Members
84 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 20
Past 30 Days: 53
All Time: 2,322
