Sony Cyber-shot DSC-P9 Flash Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
2
Past 30 Days:
39
All Time:
1,181
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 - 35 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
  • Phillips #000 Screwdriver
    4.9
  • Spudger
    4.9
    1. Sony Cyber-shot DSC-P9 Flash Replacement, Battery: step 1, image 1 of 1
      • Slide the battery latch down the side of the camera with your hands.
      • The latch will automatically pop open.
      Ask FixBot
    2. Sony Cyber-shot DSC-P9 Flash Replacement: step 2, image 1 of 1
      • Unlatch the clip over the battery.
      • The battery will partially pop out.
      Ask FixBot
    3. Sony Cyber-shot DSC-P9 Flash Replacement: step 3, image 1 of 2 Sony Cyber-shot DSC-P9 Flash Replacement: step 3, image 2 of 2
      • Remove the battery from the camera.
      Ask FixBot
    1. Sony Cyber-shot DSC-P9 Flash Replacement, Outer Casing: step 4, image 1 of 2 Sony Cyber-shot DSC-P9 Flash Replacement, Outer Casing: step 4, image 2 of 2
      • Remove the four 3.0mm Phillips #000 screws on the top of the camera with the phillips screwdriver.
      • Remove the additional four 3.0mm Phillips #000 screws on the bottom of the camera.
      Ask FixBot
    2. Sony Cyber-shot DSC-P9 Flash Replacement: step 5, image 1 of 2 Sony Cyber-shot DSC-P9 Flash Replacement: step 5, image 2 of 2
      • Once the screws are removed, slowly remove the back casing from the rest of the camera.
      Ask FixBot
    3. Sony Cyber-shot DSC-P9 Flash Replacement: step 6, image 1 of 2 Sony Cyber-shot DSC-P9 Flash Replacement: step 6, image 2 of 2
      • Then, pull the front case away from the rest of the camera.
      Ask FixBot
    4. Sony Cyber-shot DSC-P9 Flash Replacement: step 7, image 1 of 1
      • After the casing is removed, the camera should look as shown.
      Ask FixBot
    1. Sony Cyber-shot DSC-P9 Flash Replacement, Lens: step 8, image 1 of 2 Sony Cyber-shot DSC-P9 Flash Replacement, Lens: step 8, image 2 of 2
      • Dislodge the round casing from the lens.
      • Pull it away from the rest of the camera.
      Ask FixBot
    2. Sony Cyber-shot DSC-P9 Flash Replacement: step 9, image 1 of 1
      • Unscrew the two 4.0mm Phillips #000 screws from the display.
      Ask FixBot
    3. Sony Cyber-shot DSC-P9 Flash Replacement: step 10, image 1 of 1
      • Pull the two ribbon cables out of their slots on the back circuit board.
      Ask FixBot
    4. Sony Cyber-shot DSC-P9 Flash Replacement: step 11, image 1 of 1
      • Remove the three 4.0mm Phillips #000 screws holding the back panel in place.
      Ask FixBot
    5. Sony Cyber-shot DSC-P9 Flash Replacement: step 12, image 1 of 3 Sony Cyber-shot DSC-P9 Flash Replacement: step 12, image 2 of 3 Sony Cyber-shot DSC-P9 Flash Replacement: step 12, image 3 of 3
      • Work the back panel out from under the small grey clip.
      • Slide the back panel off of the camera by dislodging it from the remaining clips.
      • Below is a flat, orange cable connecting the lens to the motherboard.
      • Be careful not to bend the back plate during this process.
      Ask FixBot
    6. Sony Cyber-shot DSC-P9 Flash Replacement: step 13, image 1 of 1
      • Turn the camera over so that you can see the front of the lens.
      • Two connectors link the lens to the motherboard.
      • Gently bring the lens away from the camera.
      Ask FixBot
    7. Sony Cyber-shot DSC-P9 Flash Replacement: step 14, image 1 of 1
      • Using the flat end of the plastic spudger tool, flip up the black tabs on the connectors.
      • Be careful not to exert too much force, as the connectors are delicate.
      Ask FixBot
    8. Sony Cyber-shot DSC-P9 Flash Replacement: step 15, image 1 of 3 Sony Cyber-shot DSC-P9 Flash Replacement: step 15, image 2 of 3 Sony Cyber-shot DSC-P9 Flash Replacement: step 15, image 3 of 3
      • Gently pull out the cables and move the lens away from the rest of the camera.
      • You should now have two distinct, separate components.
      Ask FixBot
    1. Sony Cyber-shot DSC-P9 Flash Replacement, Flash: step 16, image 1 of 1
      • Remove the 3.0mm Phillips #000 screw at the top of the battery door.
      Ask FixBot
    2. Sony Cyber-shot DSC-P9 Flash Replacement: step 17, image 1 of 2 Sony Cyber-shot DSC-P9 Flash Replacement: step 17, image 2 of 2
      • Pull off the top button piece. You will have to detach a small blue ribbon cable.
      Ask FixBot
    3. Sony Cyber-shot DSC-P9 Flash Replacement: step 18, image 1 of 2 Sony Cyber-shot DSC-P9 Flash Replacement: step 18, image 2 of 2
      • Caution: the capacitor, a black cylinder near the top of the camera, might have a charge in it, which could be harmful to you or the camera. Neutralize it by touching both wires with a screwdriver at the same time.
      Ask FixBot
    4. Sony Cyber-shot DSC-P9 Flash Replacement: step 19, image 1 of 3 Sony Cyber-shot DSC-P9 Flash Replacement: step 19, image 2 of 3 Sony Cyber-shot DSC-P9 Flash Replacement: step 19, image 3 of 3
      • Remove the flash mechanism. It is held in place by a clip on the side of the camera.
      • The capacitor and flash will rotate out, still attached by a ribbon cable on the left.
      Ask FixBot
    5. Sony Cyber-shot DSC-P9 Flash Replacement: step 20, image 1 of 2 Sony Cyber-shot DSC-P9 Flash Replacement: step 20, image 2 of 2
      • Lift up the black tab with the spudger.
      • Gently remove the ribbon cable from the rest of the camera.
      • The flash component is now completely separate from the rest of the camera.
      Ask FixBot
Andrew Forster
12 Reputation
2 Guides authored
Cal Poly, Team 17-25, Amido Spring 2012 Member of Cal Poly, Team 17-25, Amido Spring 2012
CPSU-AMIDO-S12S17G25
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 39
All Time: 1,181
