Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Robot Not Collecting Debris
The robot is moving around a room but fails to pick up any debris
Dirty Side Brushes
Ensure that the brushes beneath the robot are clean and in good condition. If hair or a build up of debris is found, take the following steps:
  • Remove the brushes from the base of the robot
  • Using a damp microfiber cloth, clean the bristles of any hair or obstructions
If upon inspection the brushes seem worn, consider purchasing replacements.
Dirty Main Brush
Ensure the main brush is in good health and free from debris. Access the main brush and cleaning bristles. Remove the end cap of the main brush and clear it of any hair. Use a damp microfiber cloth to clean out any dirt or hair built up on the brush, cap, and cleaning bristles. If upon inspection the brush or cleaning bristles seem worn, consider replacing these components with this guide: Shark ION Robot R75 Main Brush Replacement
Faulty Brush Motors
 If the robot isn’t collecting debris, there is a chance that one of the brush motors has failed. Inspect the robot to see if the brushes are turning. Before purchasing new motors, check to see if there are any obstructions or buildups in or around the brushes. If none are found and the brushes aren’t moving, the motors may need replacement. Replace brush motors with this guide: Shark ION Robot R75 Side Brush Motor Replacement
Error Light Indicators
If the “!” indicator light is displayed or flashing on the Shark ION ROBOT, it indicates that there is an error.
All LED Lights are Off
If no lights are showing, this may indicate that the robot may be turned off or that the battery may need charging. To fix this error, press the power switch. If there is no response, place the robot on the charging dock.
Clean RED + “i” Flashing Together
If the Clean RED + “i” are flashing together, it indicates that the suction motor has failed. To fix this error, remove any blockage and clean the filters. Check that there is no obstruction that would otherwise prevent suction.
Clean RED or MAX Light Flashing
 If the Clean RED or Max light is flashing, it means that the robot may be stuck on an obstacle or the front bumper may be jammed. To fix this error, relocate the robot to a different location and inspect the bumper. If light continues to flash, try to remove the front caster wheel and clean the wheel housing.
Dock Light is Flashing
If the Dock light is flashing, it indicates that the robot’s BotBoundary sensors are malfunctioned. To fix this error, make sure to contact Customer Service at 1-800-798-7398.
Clean RED/DOCK Flashing Together
If the Clean RED/DOCK lights are flashing together, then the cliff sensors may have malfunctioned. To fix this error, clean the cliff sensors.
Clean RED/MAX Flashing Together
If the Clean RED/MAX lights are flashing together, it indicates that the dust bin may have been removed. To fix this error, reinsert the dust bin and ensure it is properly secured in place.
MAX/”i” Flashing Together
If MAX/ “i” are flashing together, it indicates that one of the side brushes are stuck. To fix this error, remove any debris from the side brushes.
Clean RED/MAX/ “i” Flashing Together
If Clean RED/MAX/ “i” are flashing together, it indicates that a wheel has been stuck. To fix this error, remove any debris from the wheel(s).
DOCK/MAX/ “i” Flashing Together
If DOCK/MAX/ “i” are flashing together, it indicates a blockage in the main brush. To fix this error, remove any debris or obstruction.
Irregular Robot Movement
Robot movement is sporadic and abnormal.
Dirty Sensors
The easiest fix for irregular movement usually comes from cleaning out the robot’s sensors. Use either a dry microfiber cloth or compressed air to clean the sensors around the bumper and underside of the robot.
Dirty or Worn Wheels
Inspect the drive wheels and caster wheels to ensure that they are free of any obstruction. This is commonly caused by dirt and hair. If upon inspection the wheels seem worn, you may want to consider replacing them.
For a guide on replacing drive wheels, click here: Shark ION Robot R75 Drive Wheel Assembly Replacement
For a guide on replacing the caster wheel, click here: Shark ION Robot R75 Caster Wheel Replacement
Worn Motors
If the robot seems to have trouble moving, especially on a smooth, hard surface (non-carpet), one or both of the drive motors may need to be replaced. Before considering purchasing replacement motors, ensure that the wheels are in good condition and free of obstructions.
For a guide on drive motor replacement, click here: Shark ION Robot R75 Drive Wheel Assembly Replacement
Robot Stops Moving After a Few Minutes
The robot moves around as normal, however, it freezes in place a few minutes in.
Battery Level
Verify that the device is powered on and that the battery has a sufficient charge
Obstruction in the wheels
Ensure that the front and rear wheels of the robot are moving freely and clear of any debris that may accumulate and prevent them from moving properly.
Main Brush is clogged
Remove the main brush, and check for a build-up of hair or debris that may have clogged the brush. Remove both sections of the end cap that drives the brush while also removing any hair that has built up.
Worn Drive Motors
If the robot fails to move, there is a chance that one or both of the motors has encountered an issue. Check to see if the motors are making any abnormal sounds, feels hard to turn, or if there is some form of debris stopping them from turning the wheels. If none of these issues are present, then you may want to consider replacing a motor.
Robot Does not Charge
When the robot is docked, it does not charge as it is designed to.
Power Source
Make sure that the charging dock is fully plugged into a wall outlet, power strip, or any other source of power you are utilizing. If it is plugged into a power strip or similar source, ensure that it is switched to on.
Fully Docked
Be sure that when the robot is docked, there are no obstructions that might restrict it from docking fully. This includes small debris.
Battery
Verify that the device’s battery is holding at or near the specified charge time. If not, the battery may need to be replaced.
For a guide on replacing the battery, click here: Shark ION Robot R75 Battery Replacement
134 Comments
Why does my shark suddenly start cleaning in the middle of the night?
Donna - Reply Share
Do you have pets? Our cats turn on the Shark!
caroledits - Reply Share
My kitten turns it on lol
Jamison Lynn - Reply Share
Mine was flashing error msg. that meant roller was dirty. No it wasn’t. The next step was to throw it away so being the kind of person that thinks if you have a hammer you can fix anything, I picked it up about two feet and dropped it. Guess what. It started working!!!
Sheila White - Reply Share
This is the best piece of advice out there. Tried cleaning everything then replacing everything. Then I dropped it from 2 feet and it works again.
Michael McDevitt - Reply Share
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 138
All Time: 156,279
