Shark ION Robot R75 Main Brush Replacement
    1. Shark ION Robot R75 Main Brush Replacement, Main Brush: step 1, image 1 of 1
      • Push on the two tabs on the edge of the main brush cover and pull up to remove the cover.
      Ask FixBot
    2. Shark ION Robot R75 Main Brush Replacement: step 2, image 1 of 1
      • Pull the main brush slightly to the right to remove it from the compartment.
      Ask FixBot
    3. Shark ION Robot R75 Main Brush Replacement: step 3, image 1 of 2 Shark ION Robot R75 Main Brush Replacement: step 3, image 2 of 2
      • Remove the rubber end cap indicated by the red circle.
      • This step is not needed for a replacement. However, it is important for maintenance. Hair will build up in this area over time, and will cause error messages to pop up, as well as stopping the R75 from cleaning and moving.
      • Inspect this component at least every six months. This time may be less if you have animals.
      Ask FixBot
1 Guide Comment
My shark ion stopped working after about 6 months and it started giving an error on the brush. I cleaned my vacuum pretty regularly, at least once a week. I ordered a replacement brush and it still hasn't fixed it. Do you have any other suggestions?
Tina Hicks - Reply Share
Past 24 Hours: 7
Past 7 Days: 27
Past 30 Days: 93
All Time: 3,907
