Shark ION Robot R75 Battery Replacement
    1. Shark ION Robot R75 Battery Replacement, Battery: step 1, image 1 of 3 Shark ION Robot R75 Battery Replacement, Battery: step 1, image 2 of 3 Shark ION Robot R75 Battery Replacement, Battery: step 1, image 3 of 3
      • Make sure the robot is shut off by pressing the power button on top.
      • Flip the R75 over so that the underside is facing up.
      • Using a Phillips #1 screwdriver, remove the 4mm screw in the battery cover.
      • Remove the battery cover.
      Ask FixBot
    2. Shark ION Robot R75 Battery Replacement: step 2, image 1 of 3 Shark ION Robot R75 Battery Replacement: step 2, image 2 of 3 Shark ION Robot R75 Battery Replacement: step 2, image 3 of 3
      • Be careful when removing the battery, as it will still be connected to a wire.
      • Slowly pull the white tabs outward to remove the battery.
      Ask FixBot
    3. Shark ION Robot R75 Battery Replacement: step 3, image 1 of 2 Shark ION Robot R75 Battery Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Be careful when removing the connector, as the part can break if too much force is used.
      • Push down on the tab of the battery connector using a set of tweezers and pull the connector away from the robot to free the wire.
      • Remove the battery from the device.
      Ask FixBot
3 other people completed this guide.
1 Guide Comment
After charging for several hours, my robotic shark stops after 10 minutes. I can push the start button and it will run for another 10 minutes. This has been repeated several times with out it docking itself. What are your thoughts on this?
Marsha Moon - Reply Share
Past 24 Hours: 4
Past 7 Days: 13
Past 30 Days: 51
All Time: 8,919
