Shark ION Robot R75 Caster Wheel Replacement
    1. Shark ION Robot R75 Caster Wheel Replacement, Shark ION Robot R75 Caster Wheel: step 1, image 1 of 1
      • Orient the device with the bottom facing up.
      Ask FixBot
    2. Shark ION Robot R75 Caster Wheel Replacement: step 2, image 1 of 3 Shark ION Robot R75 Caster Wheel Replacement: step 2, image 2 of 3 Shark ION Robot R75 Caster Wheel Replacement: step 2, image 3 of 3
      • Using a plastic opening tool, pry first one side of the wheel, then the other out of the caster.
      • Remove the wheel.
      Ask FixBot
    3. Shark ION Robot R75 Caster Wheel Replacement: step 3, image 1 of 3 Shark ION Robot R75 Caster Wheel Replacement: step 3, image 2 of 3 Shark ION Robot R75 Caster Wheel Replacement: step 3, image 3 of 3
      • Using a Torx TR9 screwdriver, remove both screws from the caster assembly beneath the wheel.
      • Pull the caster assembly up from its slot in the device.
      Ask FixBot
1 Guide Comment
Thanks, my compliments to your clear, simple instructions. And I love my shark AV2500 self-emptying machine--but when will manufactures realize small buy normal Philips screwheads doesn't cost more than chump change on a unit but make it A WHOLE LOT EASYER ON THEIR CUTOMERS.
Dennis King - Reply Share
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 36
All Time: 6,196
