The Oster 6329 Toaster is a commercial grade toaster
Toaster won't turn on
"The toaster has no feedback"
Plugged In
Check to make sure that the toaster is properly plugged into an outlet with power.
Power Cord Failure
If the power cord fails, nothing on the toaster will function. The most common cause of complete failure is the power cord malfunctioning. In this case, the best option is to replace the Power Cord.
Oster 6329 Power Cord Replacement
Bread is incorrectly toasted
"The toast is consistently either too light or too dark"
Toaster Knob is in wrong location
If the bread is too light, first try turning the knob clockwise to increase heating temperature. If the bread is too dark, first try turning the knob counterclockwise to lower heating temperature.
Resistor has failed
If toast is consistently either too light on the darkest setting, or too dark on the lowest setting, it may be a resistor malfunction. Most likely it is an issue with a resistor on the circuit board and the resistor must be replaced.
Oster 6329 Circuit Board Resistor Replacement
Buttons don't work
"The buttons are unresponsive"
Plugged In
Resistor has failed
If the buttons will not respond to any input, it is likely a problem with a resistor on the toaster's circuit board and the board must be replaced.
Bread will not spring up
"The bread is stuck at the bottom after the toasting is complete"
Lever Catch Spring Malfunction
If the toast is not springing up to your satisfaction, then there is most likely a problem with the springs that push the toast up when it is finished. Usually this is because the springs are old or not in good quality. In this case the springs will need to be replaced.
Oster 6329 Lever Catch Spring Replacement
Bread Lift Shelf misaligned
Another possible problem could be that the lift shelf itself is not properly aligned within the toaster. This is easy to diagnose because the lift shelf itself will be out of its track and loose within the device. To fix this a new lift shelf must be installed.
Replacing Oster 6329 Bread Lift Shelf
Resistor has failed
If one of the resistors has failed, the toaster will not work the way it was designed to. This problem is difficult to diagnose, but one common cause is the R3 resistor failing. In this case you must replace the R3 resistor.
Bread is toasted more on one side
"The bread is very toasted on one side but not the other"
Bread Grabber Spring Malfunction
If the bread is unevenly toasted, it may be caused by a problem with the bread grabbing springs. This can be easily diagnosed by watching your toaster to see if the bread is being properly positioned during toasting. If the clasps on the side are not springing together prior to toasting, there is most likely a problem with the springs that make this process happen. The best option is to replace these springs.
Oster 6329 Bread Grabber Spring Replacement
Toaster turns on by itself
"The toaster will spontaneously turn itself on without the lever being pushed down"
Resistor has failed
Power Cord Failure
If the power cord fails, nothing on the toaster may turn on by itself. In this case, the best option is to replace the Power Cord.
Author
with
Blaine Oelkers
131 Reputation
1 Guide authored
Cal Poly, Team 13-15, Regan Winter 2014 Member of Cal Poly, Team 13-15, Regan Winter 2014
CPSU-REGAN-W14S13G15
5 Members
72 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 22
All Time: 3,953
