Up to 20% off select tools
Oster 6329 Lever Catch Spring Replacement
Views: 2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
81
All Time:
1,964
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Replacing the spring can be somewhat difficult, so be prepared to deal with a little frustration when removing the spring.
    1. Oster 6329 Lever Catch Spring Replacement, Outer Shell Removal: step 1, image 1 of 2 Oster 6329 Lever Catch Spring Replacement, Outer Shell Removal: step 1, image 2 of 2
      • Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
      Ask FixBot
    2. Oster 6329 Lever Catch Spring Replacement: step 2, image 1 of 1
      • Push the plastic push-down handle down and pull the plastic handle straight from metal arm.
      Ask FixBot
    3. Oster 6329 Lever Catch Spring Replacement: step 3, image 1 of 1
      • Loosen the outer metal shell from the plastic base by holding the plastic base while pulling up on the metal shell.
      • Only lift the outer shell a little so as not to disconnect the cables that connect the circuit board.
      Ask FixBot
    4. Oster 6329 Lever Catch Spring Replacement: step 4, image 1 of 2 Oster 6329 Lever Catch Spring Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Disconnect the cable clips from the circuit board using the tweezers to free the outer metal shell from the plastic base.
      Ask FixBot
    5. Oster 6329 Lever Catch Spring Replacement: step 5, image 1 of 2 Oster 6329 Lever Catch Spring Replacement: step 5, image 2 of 2
      • Lift the top outer metal shell.
      • Carefully lift the outer metal shell at an angle so as not to damage the components in the front of the toaster.
      Ask FixBot
    1. Oster 6329 Lever Catch Spring Replacement, Lever Catch Spring: step 6, image 1 of 1
      Buy
      • Insert the tweezers between the spring and the bottom of the lever to release the spring.
      Ask FixBot
    2. Oster 6329 Lever Catch Spring Replacement: step 7, image 1 of 2 Oster 6329 Lever Catch Spring Replacement: step 7, image 2 of 2
      • Remove spring from the bottom of the lever.
      • The spring should only be connected to the top of the toaster after this is complete.
      Ask FixBot
    3. Oster 6329 Lever Catch Spring Replacement: step 8, image 1 of 1
      • Insert the tweezers between the two metal flaps located at the top of the toaster.
      • Hold the spring and turn it sideways to lay it flat along the top of the toaster.
      • Pry the spring from the top of the toaster.
      Ask FixBot
Author
with
Blaine Oelkers
131 Reputation
1 Guide authored
Cal Poly, Team 13-15, Regan Winter 2014 Member of Cal Poly, Team 13-15, Regan Winter 2014
CPSU-REGAN-W14S13G15
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 81
All Time: 1,964
