Up to 20% off select tools
Oster 6329 Bread Grabber Spring Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
Past 7 Days:
18
Past 30 Days:
82
All Time:
1,610
Comments: 1
1 comment on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 - 30 minutes
Difficulty: Very difficult
Tools
Introduction
Go to step 1 ↓
This repair is challenging because the wire that acts as the spring is difficult to bend into the correct shape.
    1. Oster 6329 Bread Grabber Spring Replacement, Outer Shell Removal: step 1, image 1 of 2 Oster 6329 Bread Grabber Spring Replacement, Outer Shell Removal: step 1, image 2 of 2
      • Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
      Ask FixBot
    2. Oster 6329 Bread Grabber Spring Replacement: step 2, image 1 of 1
      • Push the plastic push-down handle down and pull the plastic handle straight from metal arm.
      Ask FixBot
    3. Oster 6329 Bread Grabber Spring Replacement: step 3, image 1 of 1
      • Loosen the outer metal shell from the plastic base by holding the plastic base while pulling up on the metal shell.
      • Only lift the outer shell a little so as not to disconnect the cables that connect the circuit board.
      Ask FixBot
    4. Oster 6329 Bread Grabber Spring Replacement: step 4, image 1 of 2 Oster 6329 Bread Grabber Spring Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Disconnect the cable clips from the circuit board using the tweezers to free the outer metal shell from the plastic base.
      Ask FixBot
    5. Oster 6329 Bread Grabber Spring Replacement: step 5, image 1 of 2 Oster 6329 Bread Grabber Spring Replacement: step 5, image 2 of 2
      • Lift the top outer metal shell.
      • Carefully lift the outer metal shell at an angle so as not to damage the components in the front of the toaster.
      Ask FixBot
    1. Oster 6329 Bread Grabber Spring Replacement, Bread Grabber Spring: step 6, image 1 of 1
      • Press down on the toaster handle to access to the grabber spring located behind the large metal plate.
      Ask FixBot
    2. Oster 6329 Bread Grabber Spring Replacement: step 7, image 1 of 1
      • Locate the grabber spring.
      Ask FixBot
    3. Oster 6329 Bread Grabber Spring Replacement: step 8, image 1 of 1
      • Use the large needle nose pliers to unwind the grabber spring from one side of the carriage to remove.
      • Repeat this step for the opposite side.
      Ask FixBot
    4. Oster 6329 Bread Grabber Spring Replacement: step 9, image 1 of 1
      • Remove the old spring from the toaster unit to insert new.
      Ask FixBot
3 other people completed this guide.
Author
with
Isaac Williams
237 Reputation
2 Guides authored
Cal Poly, Team 13-15, Regan Winter 2014 Member of Cal Poly, Team 13-15, Regan Winter 2014
CPSU-REGAN-W14S13G15
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 82
All Time: 1,610
