MacBook Pro 15" Touch Bar Late 2016 Battery Replacement
    1. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement, Disable Auto Boot: step 1, image 1 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement, Disable Auto Boot: step 1, image 2 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement, Disable Auto Boot: step 1, image 3 of 3
      • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
      • Power on your Mac and launch Terminal.
      • Copy and paste the following command (or type it exactly) into Terminal:
      • sudo nvram AutoBoot=%00
      • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
      • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
      • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
      • sudo nvram AutoBoot=%03
      Ask FixBot
    1. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement, Lower Case: step 2, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Completely power off and unplug your MacBook Pro before you begin.
      • Close the display and flip the entire laptop upside-down.
      • Use a P5 Pentalobe driver to remove six screws securing the lower case, of the following lengths:
      • Four 4.7 mm screws
      • Two 6.6 mm screws
      • Note the orientation of the screws as you remove them—they need to be reinstalled at a slight angle.
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
      Ask FixBot
    2. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 3, image 1 of 2 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 3, image 2 of 2
      • Press a suction handle into place near the front edge of the lower case, between the screw holes.
      • Lift up on the suction handle just enough to open a small gap under the lower case.
      Ask FixBot
    3. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 4, image 1 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 4, image 2 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 4, image 3 of 3
      • Slide the corner of an opening pick into the gap you just created underneath the lower case.
      • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
      • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
      Ask FixBot
    4. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 5, image 1 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 5, image 2 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 5, image 3 of 3
      • Repeat the previous step on the opposite side, using your opening pick to release the second clip.
      Ask FixBot
    5. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 6, image 1 of 1
      • Lift the front edge of the lower case (the side opposite the display hinge) just enough to slide your fingertips underneath and get a good grip on it.
      • Two additional hidden clips near the middle of the cover should pop free at this point, if they haven't already.
      • Don't lift more than an inch or so, and don't try to remove the lower case yet.
      Ask FixBot
    6. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 7, image 1 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 7, image 2 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 7, image 3 of 3
      • Insert the flat end of a spudger into the hinge cutout in the lower case, at the corner nearest the headphone jack.
      • Pry to lever the lower case away from the hinge area, pushing it slightly towards the front edge of the MacBook.
      • Repeat at the opposite side of the cutout.
      Ask FixBot
    7. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 8, image 1 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 8, image 2 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 8, image 3 of 3
      • Mind your fingers or wear protective gloves during this step—the case edges may be very sharp.
      • Grab the front edge of the lower case again, and pull firmly to slide it towards the front edge of the MacBook (away from the hinge area), separating the last of the clips.
      • Pull first at one corner, then the other.
      • Pull to the side—not up.
      Ask FixBot
    8. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 9, image 1 of 2 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 9, image 2 of 2
      • Remove the lower case.
      • To reinstall the lower case:
      • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
      • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips. You should feel and hear them click into place.
      Ask FixBot
    1. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement, MacBook Pro 15" Touch Bar Late 2016 Battery Disconnection: step 10, image 1 of 2 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement, MacBook Pro 15" Touch Bar Late 2016 Battery Disconnection: step 10, image 2 of 2
      • Peel up and remove the large rectangular battery board cover, on the edge of the logic board nearest the battery.
      • If the cover doesn't peel up easily, apply mild heat with an iOpener, hair dryer, or heat gun to soften the adhesive underneath, and try again.
      • If the cover doesn't seat securely during reassembly, try rotating it 180 degrees. It must be oriented correctly in order for the adhesive pads underneath to contact the board screws.
      Ask FixBot
    2. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 11, image 1 of 2 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 11, image 2 of 2
      • Peel back the tape covering the battery board data cable connector.
      • The tape may not detach completely; just peel it back enough to access the connector.
      Ask FixBot
    3. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 12, image 1 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 12, image 2 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 12, image 3 of 3
      • Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
      Ask FixBot
    4. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 13, image 1 of 2 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 13, image 2 of 2
      • Disconnect the battery board data cable by sliding it out from its socket.
      • Slide parallel to the logic board, in the direction of the cable.
      Ask FixBot
    5. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 14, image 1 of 2 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 14, image 2 of 2
      • Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
      Ask FixBot
    6. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 15, image 1 of 2 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 15, image 2 of 2
      • Use a spudger to gently lift the battery power connector, disconnecting the battery.
      • Lift the connector high enough to keep it separated from its socket while you work. If it accidentally makes contact, it could damage your MacBook Pro.
      Ask FixBot
    1. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement, Trackpad Assembly: step 16, image 1 of 2 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement, Trackpad Assembly: step 16, image 2 of 2
      • Use a T3 Torx driver to remove the two 1.9 mm screws securing the trackpad cable's cover bracket.
      • Remove the bracket.
      Ask FixBot
    2. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 17, image 1 of 2 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 17, image 2 of 2
      • Use a spudger to disconnect the trackpad cable by prying its connector straight up from the logic board.
      Ask FixBot
    3. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 18, image 1 of 1
      • Apply mild heat to the trackpad ribbon cable to soften the adhesive securing it to the battery.
      • You can use an iOpener, hair dryer, or heat gun, but be careful not to overheat the battery. The cable should be warm, but not too hot to touch.
      Ask FixBot
    4. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 19, image 1 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 19, image 2 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 19, image 3 of 3
      • Carefully peel the trackpad cable up off the battery, and push it out of the way.
      • Don't fold or tear the cable. If you have trouble, don't force it—apply more heat and try again.
      Ask FixBot
    5. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 20, image 1 of 2 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 20, image 2 of 2
      • Use a T5 Torx driver to remove the 13 screws securing the trackpad assembly:
      • Nine 5.8 mm screws
      • Four 4.9 mm screws
      • These screws look very similar, so don't mix them up.
      • These screws can loosen over time due to the clicking action on the Force Touch trackpad. Adding a little blue threadlocker as you install them can help keep them secure.
      • Install the screws loosely and check the trackpad alignment before tightening them down.
      Ask FixBot
    6. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 21, image 1 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 21, image 2 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 21, image 3 of 3
      • Swing the display open slightly, but keep the MacBook upside-down. The trackpad assembly should separate and lay flat on the display.
      • Gently feed the trackpad's ribbon cable through its slot in the chassis.
      • Carefully note the correct slot for the trackpad cable during reassembly—it goes through the narrow slot alongside the battery, not the bigger slot near the MacBook Pro's front edge.
      Ask FixBot
    7. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 22, image 1 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 22, image 2 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 22, image 3 of 3
      • As you remove the trackpad assembly, be very careful not to lose the nine small metal washers resting on the screw posts. (They will fly off and get lost with very little provocation.)
      • Remove the trackpad assembly.
      Ask FixBot
    1. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement, Logic Board Assembly: step 23, image 1 of 2 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement, Logic Board Assembly: step 23, image 2 of 2
      • Using a T3 Torx driver, remove the two 1.9 mm screws securing the keyboard connector cover bracket.
      Ask FixBot
    2. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 24, image 1 of 2 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 24, image 2 of 2
      • Use your spudger to disconnect the keyboard by prying its connector straight up from the logic board.
      Ask FixBot
    3. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 25, image 1 of 2 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 25, image 2 of 2
      • Use a T3 Torx driver to remove the two 3.5 mm screws securing the cover on the display board flex cable.
      • Remove the display board flex cable cover.
      Ask FixBot
    4. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 26, image 1 of 2 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 26, image 2 of 2
      • Use a T3 Torx driver to remove the two 1.7 mm screws securing the bracket for the display board cable connector.
      • Remove the bracket from the display board cable connector.
      Ask FixBot
    5. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 27, image 1 of 2 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 27, image 2 of 2
      • Pry straight up with your spudger to disconnect the display board flex cable.
      Ask FixBot
    6. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 28, image 1 of 2 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 28, image 2 of 2
      • Use a T3 Torx driver to remove the two 2.0 mm screws securing each hinge cover (four screws total).
      Ask FixBot
    7. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 29, image 1 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 29, image 2 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 29, image 3 of 3
      • Remove both hinge covers.
      Ask FixBot
    8. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 30, image 1 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 30, image 2 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 30, image 3 of 3
      • Use a T3 Torx driver to remove the two 2.4 mm screws securing the cover bracket for the Touch ID and headphone jack cable connectors.
      Ask FixBot
    9. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 31, image 1 of 2 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 31, image 2 of 2
      • Disconnect the headphone jack cable by prying its connector straight up from the logic board.
      Ask FixBot
    10. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 32, image 1 of 2 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 32, image 2 of 2
      • Disconnect the power button and Touch ID sensor by prying its connector straight up from the logic board.
      Ask FixBot
    11. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 33, image 1 of 1
      • Use a T3 Torx driver to remove the 1.3 mm screw securing the cover bracket for the Touch Bar digitizer connector.
      Ask FixBot
    12. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 34, image 1 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 34, image 2 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 34, image 3 of 3
      Buy
      • Using your tweezers, slide the bracket toward the side edge of the MacBook Pro until it clears the slotted retaining tab on the logic board.
      Ask FixBot
    13. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 35, image 1 of 2 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 35, image 2 of 2
      • Disconnect the Touch Bar digitizer cable by prying it straight up from the logic board.
      Ask FixBot
    14. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 36, image 1 of 2 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 36, image 2 of 2
      • Use a T3 Torx driver to remove the two 1.9 mm screws securing the bracket for the Touch Bar display cable connector.
      Ask FixBot
    15. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 37, image 1 of 2 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 37, image 2 of 2
      • Disconnect the Touch Bar display cable by prying its connector straight up from the logic board.
      Ask FixBot
    16. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 38, image 1 of 2 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 38, image 2 of 2
      • Use a T3 Torx driver to remove the four 1.3 mm screws securing the Thunderbolt flex cable covers:
      • Two screws on the left
      • Two more on the right
      Ask FixBot
    17. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 39, image 1 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 39, image 2 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 39, image 3 of 3
      • Disconnect the left-side Thunderbolt flex cable by prying it straight up from the logic board.
      • Pry from the inside edge, nearest the fan.
      • Gently push the flex cable connector off to the side so it doesn't interfere with logic board removal.
      Ask FixBot
    18. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 40, image 1 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 40, image 2 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 40, image 3 of 3
      • Repeat to disconnect the Thunderbolt flex cable connector on the opposite side.
      • Carefully push the flex cable connector aside so there's clearance for the logic board to come out without snagging.
      Ask FixBot
    19. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 41, image 1 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 41, image 2 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 41, image 3 of 3
      • Disconnect the two speaker connectors by sliding the flat end of your spudger underneath each cable near its connector.
      • Gently twist or pry up to disconnect both speakers.
      Ask FixBot
    20. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 42, image 1 of 2 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 42, image 2 of 2
      • Peel up any tape covering the microphone cable connector socket.
      Ask FixBot
    21. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 43, image 1 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 43, image 2 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 43, image 3 of 3
      • Open the locking flap on the microphone cable's ZIF connector by prying it straight up from the logic board.
      Ask FixBot
    22. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 44, image 1 of 2 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 44, image 2 of 2
      • Disconnect the microphone by pulling its cable toward the fan until it releases from its socket.
      • If possible, pull on the tape attached to the cable, rather than the cable itself, to reduce the risk of damage.
      Ask FixBot
    23. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 45, image 1 of 1
      • Use a T5 Torx driver to remove the single 2.9 mm screw securing the antenna cable bundle.
      Ask FixBot
    24. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 46, image 1 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 46, image 2 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 46, image 3 of 3
      • Disconnect all three antenna cables by prying each one straight up from its socket.
      • Slide your tweezers or the flat end of your spudger underneath each cable until it's near the socket, and then gently twist or pry up to disconnect it.
      • To reconnect each cable, align the connector directly over its socket, and then press down so it snaps into place.
      Ask FixBot
    25. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 47, image 1 of 2 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 47, image 2 of 2
      • Remove the ten screws securing the logic board assembly:
      • Two 2.8 mm T3 Torx screws
      • Five 2.9 mm T5 Torx screws
      • One 3.7 mm T5 Torx screw
      • One 3.9 mm T8 Torx screw
      • One 3.8 mm T8 Torx screw
      • During reassembly, install these screws only loosely. Adjust the board position if necessary until all the connectors line up, and then tighten the screws.
      Ask FixBot
    26. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 48, image 1 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 48, image 2 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 48, image 3 of 3
      • Peel up (but don't remove) the two rubber vibration damping strips from the adhesive holding them to the fans.
      • If needed, apply mild heat with an iOpener, hair dryer, or heat gun to soften the adhesive and make the dampers easier to separate.
      Ask FixBot
    27. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 49, image 1 of 2 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 49, image 2 of 2
      • The logic board assembly is a tight fit, but you can make it easier to remove by inserting a spudger under the left edge and levering it up slightly.
      • There should be no resistance as you remove the logic board. Check all cables carefully and hold them out of the way if needed so they don't snag on the board.
      • Lifting from the left side, remove the logic board.
      Ask FixBot
    28. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 50, image 1 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 50, image 2 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 50, image 3 of 3
      • When reinstalling the logic board assembly:
      • Check the alignment of the rubber vibration dampers, and adjust them as needed.
      • Feed the antenna cable bundle through the gap between the logic board and heat sink, and make sure it lines up correctly as you lower the board into place.
      • Verify that no cables get trapped under the board as you install it. Check each marked location carefully.
      Ask FixBot
    1. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement, Battery: step 51, image 1 of 2 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement, Battery: step 51, image 2 of 2
      • Remove the two screws securing the battery board:
      • 2016-2017 models: Use a T5 Torx driver to remove both 3.5 mm screws.
      • 2018-2019 models: Use a P2 Pentalobe driver to remove both 3.2 mm screws.
      Ask FixBot
    2. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 52, image 1 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 52, image 2 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 52, image 3 of 3
      • The liquid adhesive remover provided in your kit can damage the antireflective coating on your MacBook Pro's display, as well as the plastic keyboard keys.
      • To protect your display, place a sheet of aluminum foil between the display and keyboard and leave it there while you work.
      • Additionally, use painter's tape to seal off the area under the trackpad as best you can. Optionally, you may also layer an absorbent towel directly underneath the trackpad area to soak up any excess adhesive remover.
      Ask FixBot
    3. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 53, image 1 of 2 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 53, image 2 of 2
      • To control the flow of adhesive remover, raise the back edge (hinge side) of your MacBook Pro a few inches using a book or foam block.
      Ask FixBot
    4. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 54, image 1 of 2 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 54, image 2 of 2
      • Now that your MacBook Pro is fully prepped, it's time to prep yourself.
      • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
      • Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
      • Do not wear contact lenses without eye protection.
      • Protective gloves are also included in your kit. If you are concerned about possible skin irritation, put your gloves on now.
      Ask FixBot
    5. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 55, image 1 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 55, image 2 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 55, image 3 of 3
      • Pull off the black rubber stopper from your bottle of adhesive remover.
      • Twist to loosen or remove the bottle cap before you cut the applicator tip.
      • This unseals the bottle and allows the pressure to equalize before you cut the applicator tip. If you skip this step, the adhesive remover may spray out unexpectedly when the tip is cut.
      • Use scissors to cut off the sealed tip of the applicator.
      • Cutting close to the narrow tip will give you better control so you can apply the adhesive remover in small amounts.
      • Twist and close the bottle cap securely before you proceed further.
      Ask FixBot
    6. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 56, image 1 of 2 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 56, image 2 of 2
      • Apply a few drops of adhesive remover underneath the two battery cells on the right, starting along the edge nearest the fan.
      • You don't need to use very much. The small bottle contains more than twice the amount of solvent needed to remove all the battery cells.
      Ask FixBot
    7. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 57, image 1 of 2 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 57, image 2 of 2
      • Add a few more drops of adhesive remover in between the two battery cells on the right, so that it flows down underneath the lower battery cell.
      • Wait about two minutes for the liquid adhesive remover to penetrate and weaken the battery adhesive before you proceed to the next step.
      Ask FixBot
    8. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 58, image 1 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 58, image 2 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 58, image 3 of 3
      Plastic Cards
      $2.99
      Buy
      • After a couple minutes, insert one corner of a plastic card underneath the battery, starting from the lower edge of the bottom, right-most cell.
      • This shouldn't require much force. If you have trouble, apply more adhesive remover and give it 2-3 additional minutes to penetrate.
      • Try not to deform the battery. A damaged or punctured battery can leak dangerous chemicals and/or catch fire.
      • Wiggle the card from side to side and slide it all the way underneath both battery cells.
      • Lift the cells to fully separate the adhesive, but don't try to remove them from your MacBook yet.
      • Leave the plastic card temporarily underneath the cells to prevent the adhesive from re-bonding as you proceed to the next step.
      Ask FixBot
    9. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 59, image 1 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 59, image 2 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 59, image 3 of 3
      • Switch to the left side of the MacBook Pro, and repeat the previous step to separate two more battery cells.
      • Leave the second plastic card in place temporarily.
      Ask FixBot
    10. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 60, image 1 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 60, image 2 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 60, image 3 of 3
      • Apply a few drops of adhesive remover along the top edges of the two center battery cells.
      • There are openings in the chassis underneath these two cells, which allow the adhesive remover to leak through and may prevent it from fully penetrating.
      • Be mindful of leaks, and apply more adhesive remover along the side edges if needed.
      Ask FixBot
    11. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 61, image 1 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 61, image 2 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 61, image 3 of 3
      • After a couple minutes, retrieve your first plastic card and insert one corner under the top edge of one of the center battery cells.
      • Wiggle it from side to side and slide it underneath the battery cell until all the adhesive separates.
      • If you have trouble, don't use excessive force and don't deform the battery. Apply more adhesive remover and try again, or skip down two steps for an alternate method.
      Ask FixBot
    12. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 62, image 1 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 62, image 2 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 62, image 3 of 3
      • Retrieve your second plastic card and repeat the previous step to separate the remaining center battery cell.
      Ask FixBot
    13. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 63, image 1 of 1
      • If you had trouble getting the card underneath any of the battery cells, try working a piece of floss or wire underneath the battery cell and pull it side-to-side in a sawing motion to separate the adhesive.
      • Wear thick gloves or wrap the floss around a couple of driver handles so as not to hurt your fingers.
      Ask FixBot
    14. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 64, image 1 of 2 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 64, image 2 of 2
      Buy
      • Lift and remove the battery.
      • Before installing a new battery, remove all remaining adhesive from the MacBook Pro's case.
      • Peel off any large strips of adhesive using tweezers or gloved fingers.
      • Scrape away any remaining chunks of adhesive with a plastic tool, and clean the underlying areas with adhesive remover or isopropyl alcohol. Wipe in one direction (not back and forth) until the chassis is clean and ready for your new battery.
      • This can take quite a bit of work, so be patient.
      Ask FixBot
    15. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 65, image 1 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 65, image 2 of 3 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 65, image 3 of 3
      Tesa 61395 Tape
      $25.95
      Buy
      • Double-check the fit and alignment of your new battery before sticking it down.
      • On earlier models, be mindful of the battery data cable and make sure it doesn't get pinched or trapped under the battery board.
      • If your battery came with adhesive pre-installed on the bottom, flip it over and carefully peel away the liner to expose the adhesive. If your battery did not come with adhesive, apply a thin double-sided adhesive tape such as Tesa 61395 to keep your battery in place.
      • Carefully position the battery and set it into place.
      • Press and hold each cell firmly for 5-10 seconds to secure it to the lower case.
      Ask FixBot
    16. MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 66, image 1 of 2 MacBook Pro 15" Touch Bar Late 2016 Battery Replacement: step 66, image 2 of 2
      • After your battery is properly positioned and installed, peel off and discard the clear plastic liner from the top.
      • Make sure the liner doesn't accidentally pull off any of the black battery component coverings. If needed, use tweezers to hold them in place as you peel off the liner.
      • Calibrate your newly installed battery: charge it to 100%, and keep charging it for at least 2 more hours. Unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
      • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
      Ask FixBot
120 other people completed this guide.
Jeff Suovanen
455,048 Reputation
259 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
75 Guide Comments
This is an awesome guide. My girlfriend’s MacBook Pro was diagnosed with a logic board failure by the repair centre. The repair cost was going to be more than a new 6-core Mac Mini.
I tinkered with the device, and thanks to the help of the iFixit community, a battery fault was diagnosed. Installed a new battery and the problem was solved!
Graeme Hatley - Reply Share
Everything went perfectly. Thanks for the great guide :)
Eric Sterrett - Reply Share
Hello I bougth the battery on this site my model is A1707, I followed the procedure and when I turned it on it stays in 1% and says condition: Replace now… what can I do?
Rafael Eduardo Cadenas Peña - Reply Share
Hi Rafael, make sure you’ve calibrated your battery first. If that doesn’t fix anything and you’re using an iFixit battery, contact our customer support team and they’ll help you out. Otherwise you can post your question on the Answers Forum—there are a bunch of experts there that can offer advice.
Adam O'Camb - Reply Share
My late 2016 model MBP’s battery had swollen after 3 years (2 months out of warranty). Apple wanted $850 to send it in and replace it. I purchased a new battery and it’s kit for a fourth of the price from iFixit. 2.5 hours later, and everything seems to be working smoothly. The guide was spot on.
amandalasha - Reply Share
Past 24 Hours: 29
Past 7 Days: 243
Past 30 Days: 1,085
All Time: 151,277
