MacBook Air 11" Early 2015 Battery Replacement
    1. MacBook Air 11" Early 2015 Battery Replacement, Lower Case: step 1, image 1 of 1
      Tool used on this step:
      P5 Pentalobe Screwdriver Retina MacBook Pro and Air
      $5.99
      Buy
      • Shut down and close your computer. Lay it on a soft surface top-side down.
      • Remove the following ten screws:
      • Two 8 mm 5-point Pentalobe screws
      • Eight 2.5 mm 5-point Pentalobe screws
      • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
      Ask FixBot
    2. MacBook Air 11" Early 2015 Battery Replacement: step 2, image 1 of 1
      • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
      Ask FixBot
    1. MacBook Air 11" Early 2015 Battery Replacement, Battery Connector: step 3, image 1 of 2 MacBook Air 11" Early 2015 Battery Replacement, Battery Connector: step 3, image 2 of 2
      • In this step you will disconnect the battery to help avoid shorting out any components during service.
      • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
      • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
      Ask FixBot
    1. MacBook Air 11" Early 2015 Battery Replacement, Battery: step 4, image 1 of 1
      • Remove the following five screws securing the battery to the upper case:
      • Two 5.2 mm T5 Torx screws
      • One 6 mm T5 Torx screw
      • Two 2.6 mm T5 Torx screws
      Ask FixBot
    2. MacBook Air 11" Early 2015 Battery Replacement: step 5, image 1 of 1
      • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
      • Lift the battery from its edge nearest the logic board and remove it from the upper case.
      • If you're installing a new battery, you should calibrate it after installation:
      • Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
      • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
      Ask FixBot
84 other people completed this guide.
Sam Goldheart
477,977 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,577 Guides authored
27 Guide Comments
Thank you, awesome guide and just what I needed!
Curtis - Reply Share
No muss. No fuss. Thanks
John Colmers - Reply Share
How many hours can I expect iFixit’s replacement battery to last? [for the 2015 MacBook Air 11”]
Brittany S - Reply Share
Hi All (at iFixIT),
Anyone got an answer for Brittany S? I would also like to know the answer to this question.
Many Thanks
M
Moshie - Reply Share
Hello. I bought your replacement battery and replacing was easy but I had to do it a second time because the new battery seems thicker and affected the trackpad operation. I’ve tried a second time and it looks like the trackpad is lifting on the right hand side and it doesn’t click properly. Any idea whether this is something I can sort out?
Thanks
Andrew Aldis - Reply Share
Past 24 Hours: 15
Past 7 Days: 109
Past 30 Days: 472
All Time: 72,553
